Originally posted by straumli View PostDear community, could someone please advise if this ROM is compatible with my 1 hour old device?
Details below (I have no idea if it has ddr3 or ddr4 memory, any idea how to determine that?):
System (Android 7.1.2)
Model H96 PRO+
Manufacturer Amlogic
Device q9377
Product q9377
Brand Amlogic
Android Version 7.1.2
API Level 25
Build ID NHG47L
Processor (AArch64)
Processor AArch64 Processor rev 4 (aarch64)
Cores 8
Max Frequency 1512 Mhz
Instruction Sets arm64-v8a,
SIMD Instructions Not Supported
Memory (2749 MB)
System RAM 2749 MB
JVM Max Memory 192 MB
Internal Storage 26336 MB
External Storage 26336 MB (Emulated)
EDIT: Works :-) Flashed the .IMG to SD card, booted in recovery and it installed. Now going to install the OTA (via TWRP?)
EDIT2: OTA flash via System-->Update menu worked fine as well.
Donated!
Originally posted by pfornaro View Post
Could you please tell me how to flash through SD card, plese? I would avoid USB burning tool since it scared me the last time with those plug in/off and several attempts to flash the ROM. Thanks in advance
Well dunno what can be your problem m8
My box come from factory with problems, it wont start with the remote when you shutdown, also in shutdown mode it gets hot really hot lol and now the ports are dying of all my unplug and plug again on rom making.... so... the hw is not that great on this boxes on the earlier hw revisions like yours and mine, dunno the newer ones!
Originally posted by amitabh15v View Post
In that case I will.stick with 6.0 before I keep.flashing and destroy my box. Is there absolutely no way to get magisk working on it? Also can you please give me version or APK for Netflix on 7.1.2, because that works fine as long as box doesn't hang. But on 6.0 Netflix gives me errors and I tried clearing data/cache and it doesn't help. Maybe a different version or your APK will.work and then I can happily stay on 6.0 ATV rom.
Originally posted by yodatheboss View Post
so we will do
UPDATES ARE INCREMENTAL - SCV1 (IMG) -> SCV1A (OTA) -> SCV2 (OTA) -> SCV3 (OTA) ?
WiFi can instantly be improved on any firmware just by placing the 2.4GHz antenna outside the case.
As for the usb ports I bought some 150mm extension leads and just leave them plugged in constantly. The usb port connectors are crappy so this method fixes that.
PS- Your Rom does allow for better cooling however this box must be ventilated if its to have a happy long life.
superceleron
Installed on my TX8 Max AP6255, unable to see my wifi network name. Got a method to just bypass the wifi ?
There are currently 2532 users online. 0 members and 2532 guests.
