Hi Superceleron
First of all I wanted to tell you BRAVO for this amazing work that you've done. My box is so fast with bug (except Bluetooth connection connection)
I wanted to ask you if it's possible to integrate the driver for the MINIX A3 REMOTE CONTROLER ??
Thank you so much again for your ongoing motivation and work that help us all.
Originally posted by eXcer View Post
I tried adding the device but it did not work, the tv box did not find anything. Bluetooth is disabled by default after ROM installation and I do not know how to turn it on. Any idea? Ah, the "Reboot" app does nothing, does not power off or reboot. Very strange....
And no reboot app only works after you root the rom... by default the rom is not rooter...
If you need to reboot just long press the power button!
Originally posted by christopherDurand View PostI meant. "my box is fast with NO bug" !
How could i get you the KL for the remote ? I don't really know what is a KL
Is that what you are looking for i Beleive I found it
https://www.dropbox.com/s/t9tfm5htka93x40/A3Remote.zip?dl=0
Originally posted by christopherDurand View PostIs that what you are looking for i Beleive I found it
Only the wireless part of it!
Originally posted by christopherDurand View PostThat's great !! It doesn't matter if IR doesn't work the remote is great ! And it will be just perfect with your rom! Thanks for adding it up to the built !
Just so i can put it in mind, how long is the next built going to come out
1 month maybe!
i recently bought version H96 Pro+ (no Alfawise) 3GB/16GB with android 7.1.1. The device wont play any 4K movie in Kodi 17.4, MX player, VLC and so on. It plays just sound and the screen is black on 4K LG TV. How can I solve this issue. Helps upgrade to your version 7.1.2 or is there any fix for it.
well now the H96 Pro STICK, after that update the MAX or Maybe the KIII PRO, after they give me the the L1 Key so i can make a ATV rom... and then do a RTD and so on etc...
Originally posted by Modelman View Post
The H96 pro Stick stock rom looks almost identical to the Normal H96 pro box. it should be an easy adaption for someone of your skills. Looks like they have once again failed to consider any sort of ventilation that this Octa Core device needs and must have if it's going to perform correctly. Early reports suggest it gets very hot (80c + on HD movies) when pushed hard.
And yes they have some kind of problem making ventilation holes.... but with my rom idles at 51cº and im in a hot country.. so not bad, dint try to watch a full movie... lack of time for it!
There are currently 1444 users online. 1 members and 1443 guests.
