1º The status bar... yes i forgot to enable auto hide because as you know SCV3 dint have them, i will fix in SCV4A that im going to rls today!
2º The power on after power off, dunno.. i dont have any problems with that here.
3º chromecast dont talk about it plz... or i will remove it.. sometimes it works other dont is what it is nobody can do nothing about it and mean nobody unless you pay royalties to google!
4º i dont have any ghosting on ftmc, maybe you got a bad encoded file!
5º Apps not showing Menu... like i said that is a problem of the apps itself and not the rom, what that means is they are not prepared to work 100% ok on android tv.
About ghosting it was working well before with same file ( on both normal and atv version now both have problem) also there is blurr effect on moving objects( for e.g sony logo in starting when it zoom toward you it have blurry tail i'll try to show it in pic) in both hardware acceleration and software mode. It is working fine with other players like vlc in software mode( as vlc dont support amcodec).
I will try some other files to see if it is with all or this file in particular.
See this pic of sony logo i was talking about
Also here in this scene a guy is putting his bag in his car.
Originally posted by paras0710 View PostAbout ghosting it was working well before with same file ( on both normal and atv version now both have problem) also there is blurr effect on moving objects in both hardware acceleration and software mode. It is working fine with other players like vlc in software mode( as vlc dont support amcodec)
- How I do root on this device? What is the method using Magisk?
- I need to install an app on this device to configure the wireless gamepad (a control emulator). However it is necessary to access the device through the PC and run a script by adb. Is there any way to run this script without using the PC? The gamepad in question is Mocute 050. I can not get it to work in some games like DuckTales and would need to emulate the commands on the screen. Do you know any app that does this without adb?
Originally posted by paras0710 View PostOk, Thanks may be the encoding problem then because it still has the same issue.
But I don't know why its working fine on my mobile
These are my phones screenshot 3rd one is pitch black.
Thanks anyway for the great work.
Originally posted by eXcer View Post- How I do root on this device? What is the method using Magisk?
About the 2º question sorry dunno i dont have that gamepad, but i bet the script it the driver loading!
Hi guys, finally today I'm gonna receive the H96. I want to flash this rom of course but I just have some questions. Which flash method should I use? USB or SD?
If USB Burning tool which checkmarks should I enable disable there? And especially, the most important question, after the "success" of flashing should I exit the program and plug off (and so power off) the device or just waiting for the first boot? Thanks in advance.
Originally posted by pfornaroHi guys, finally today I'm gonna receive the H96. I want to flash this rom of course but I just have some questions. Which flash method should I use? USB or SD?
In USB burning tool check all mark and normal erase option. Your device will automatically unplugged and plugged again 2 times in process once at 1% and once at 4% dont remove the cable. If successful it will disconnect your device with message burn successful then you remove usb cable and plug it to tv with hdmi cable and power adaptor and wait for 1st boot as it can take 5-6 minutes.
Note that burn process can be stopped many times with errors dont stop or close burning tool just unplug your device and plug again holding reset button burning tool automatically detects and start working from start itself.
There are currently 2952 users online. 1 members and 2951 guests.
