Imagine the ppl that dont have a mic, that mean they cant use the rom because of it, since that app only works with it.
Superceleron,
Many many thanks for this excellent ROM which has elevated H96 Pro+ no end.
One question but to the community; for the life of me i cannot get any movie with EAC3 5.1 or AC3 5.1 sound to play on PLEX (playing from a remote server btw)
Ive tried everything withing Plex ..disable passthrough, streaming rates etc but cannot get the audio to play, or am i missing something really obvious here?
not even sure if its related to this ROM tbh but thought i would ask.
thanks in advance
I like to try different ROM's by different developers, as many people already know.
However my box (H96 PRO+ 3/32Gb) is STUCK on SCV4 -ATV 7.1.2 and I can NOT perform OTA updates to Superceleron's latest ROM
Does anyone know what I can do to force this box to update?
I am handy with the USB BURNING TOOL and have the proper cables needed to install a new ROM... but I can NOT get this little Box to perform OTA updates.
I used OTA software in box and box just HANGS after it reboots.
I have tried using an SD CARD using TOOTHPICK method but Box will not boot into RECOVERY mode... so I have not been able to UPDATE ROM's that way, either.
Unfortunately it is not possible to skip the Internet connection request in the setup process. With all the Android devices I have seen yet it was always possible to simply skip this request but not with this ROM! Without granting internet access the setup process will not continue. Is this intentionally? Is there a way around it?
Originally posted by Wyle View PostI like to try different ROM's by different developers, as many people already know.
first i moved your Topic to here , no need for extra Topic if you want to ask something about this Rom , do it here .
Did you exactly that , what Superceleron wrote in first Post ??? ,
you have to flash Version 1 and than OTA to Nr.4 , i think ???
hope you get it / greettings / gefatterrn
thanks in advance
There are currently 1628 users online. 1 members and 1627 guests.
