Sent from my SM-G930F using Tapatalk
Originally posted by Akirainblack View PostSuperceleron are the OTAs cumulative or do they need to be flashed in sequence?
I am fully aware that normally they would need to be flashed in sequence, I'm only asking as they are both over 600MB.
Thanks for the Firmware I am about to experiment.
After modding my H96 Pro with a larger heatsink for cooler running, exposing the two extra USB ports and placing the 2.4Ghz dipole antenna outside the case everything is spot on. I'm hoping this now great box will become a fantastic one thanks to Superceleron.
First of all - this is a superb image! Fantastic job superceleron! I love the speed, love the Youtube, I love the design, etc. Great job overall.
This image really makes me wonder if I really need LibreELEC ;-)
My box is H96 Pro+ (Not Alfawise - although some previous SC images had Aida64 fooled and it reported it as Alfawise H96 Pro+) with 3GB DDR and 32GB eMMC.
All works - I do not use WIFI, so I really do not care if it has or has not lower speeds...
I'm running the SCV2 now (Yes, I saw nice "feature" of amcodec on SPMC on SCV1 ;-))
There are some (minor) videocodec (mediacodec/Surface and maybe on amcodec aswell) issues, but I might report those later on...
The main problem I found right now is with Audio Passthrough. It kind of seems, that Audio Passthrough is somewhat broken. I do not know if I need to change some settings or what - I have tried all kind of different settings in Settings->Audio/Sound, but passthrough simply does not work - not a simple beep comes out.
My configuration is: H96PRO+ connected through HDMI to my receiver.
So, I tested in Kodi17 (official from Play store, downloaded 64bit and 32bit from kodi.tv) and I also tested with SPMC 17a10. Plus I hear no audio in internal movie player - it detects DTS for example and then nothing is sent to receiver.
So, I enabled debug in Kodi (I can post full log also) and I see:
Code:09:46:01.899 T:529822999632 DEBUG: Firmware implements AC3 RAW 09:46:01.900 T:529822999632 DEBUG: Firmware implements EAC3 RAW 09:46:01.900 T:529822999632 DEBUG: Firmware implements DTS RAW 09:46:01.900 T:529822999632 NOTICE: AML device detected 09:46:01.901 T:529822999632 DEBUG: AESinkAUDIOTRACK - 32000 supported 09:46:01.901 T:529822999632 DEBUG: AESinkAUDIOTRACK - 44100 supported 09:46:01.903 T:529822999632 DEBUG: AESinkAUDIOTRACK - 48000 supported 09:46:01.904 T:529822999632 DEBUG: AESinkAUDIOTRACK - 88200 supported 09:46:01.905 T:529822999632 DEBUG: AESinkAUDIOTRACK - 96000 supported 09:46:01.905 T:529822999632 DEBUG: AESinkAUDIOTRACK - 176400 supported 09:46:01.906 T:529822999632 DEBUG: AESinkAUDIOTRACK - 192000 supported 09:46:01.906 T:529822999632 DEBUG: Firmware implements DTS-HD RAW 09:46:01.907 T:529822999632 DEBUG: Firmware implements TrueHD RAW 09:46:01.907 T:529822999632 DEBUG: AESinkAUDIOTrack: Using IEC PT mode: 13 09:46:01.907 T:529822999632 DEBUG: 8 Channel PT via IEC61937 is supported 09:46:01.907 T:529822999632 NOTICE: Found 1 Lists of Devices 09:46:01.907 T:529822999632 NOTICE: Enumerated AUDIOTRACK devices: 09:46:01.908 T:529822999632 NOTICE: Device 1 09:46:01.908 T:529822999632 NOTICE: m_deviceName : AudioTrack 09:46:01.908 T:529822999632 NOTICE: m_displayName : android 09:46:01.908 T:529822999632 NOTICE: m_displayNameExtra: audiotrack 09:46:01.908 T:529822999632 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 09:46:01.908 T:529822999632 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR 09:46:01.908 T:529822999632 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000 09:46:01.908 T:529822999632 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_RAW,AE_FMT_RAW 09:46:01.908 T:529822999632 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD,STREAM_TYPE_TRUEHD
SPMC reports the same...
Code:13:18:11.203 T:18446744073156253984 INFO: AESinkAUDIOTRACK - ENCODING_IEC61937 detected 13:18:11.204 T:18446744073156253984 NOTICE: Found 1 Lists of Devices 13:18:11.204 T:18446744073156253984 NOTICE: Enumerated AUDIOTRACK devices: 13:18:11.204 T:18446744073156253984 NOTICE: Device 1 13:18:11.204 T:18446744073156253984 NOTICE: m_deviceName : AudioTrackPCM 13:18:11.204 T:18446744073156253984 NOTICE: m_displayName : Android 13:18:11.204 T:18446744073156253984 NOTICE: m_displayNameExtra: PCM 13:18:11.204 T:18446744073156253984 NOTICE: m_deviceType : AE_DEVTYPE_PCM 13:18:11.205 T:18446744073156253984 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR 13:18:11.205 T:18446744073156253984 NOTICE: m_sampleRates : 32000,44100,48000,96000,192000 13:18:11.205 T:18446744073156253984 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT 13:18:11.205 T:18446744073156253984 NOTICE: m_streamTypes : No passthrough capabilities 13:18:11.205 T:18446744073156253984 NOTICE: Device 2 13:18:11.205 T:18446744073156253984 NOTICE: m_deviceName : AudioTrackPTRAW 13:18:11.205 T:18446744073156253984 NOTICE: m_displayName : Android RAW 13:18:11.205 T:18446744073156253984 NOTICE: m_displayNameExtra: Passthrough 13:18:11.205 T:18446744073156253984 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 13:18:11.205 T:18446744073156253984 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR 13:18:11.206 T:18446744073156253984 NOTICE: m_sampleRates : 32000,44100,48000,96000,192000 13:18:11.206 T:18446744073156253984 NOTICE: m_dataFormats : AE_FMT_RAW 13:18:11.206 T:18446744073156253984 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD,STREAM_TYPE_TRUEHD 13:18:11.206 T:18446744073156253984 NOTICE: Device 3 13:18:11.206 T:18446744073156253984 NOTICE: m_deviceName : AudioTrackPTIEC 13:18:11.206 T:18446744073156253984 NOTICE: m_displayName : Android IEC 13:18:11.206 T:18446744073156253984 NOTICE: m_displayNameExtra: Passthrough 13:18:11.206 T:18446744073156253984 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 13:18:11.206 T:18446744073156253984 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR 13:18:11.206 T:18446744073156253984 NOTICE: m_sampleRates : 32000,44100,48000,96000,192000 13:18:11.207 T:18446744073156253984 NOTICE: m_dataFormats : AE_FMT_RAW 13:18:11.207 T:18446744073156253984 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTS_512,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD,STREAM_TYPE_TRUEHD
Code:09:46:02.119 T:529456440400 DEBUG: Thread ActiveAE start, auto delete: false 09:46:02.119 T:529455404112 DEBUG: Thread AESink start, auto delete: false 09:46:02.120 T:529455404112 INFO: CActiveAESink::OpenSink - initialize sink 09:46:02.120 T:529455404112 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack 09:46:02.120 T:529455404112 DEBUG: CAESinkAUDIOTRACK::Initialize requested: sampleRate 44100; format: AE_FMT_FLOAT; channels: 2 09:46:02.121 T:529455404112 DEBUG: Updated SampleRate: 32000 Distance: 108900 09:46:02.121 T:529455404112 DEBUG: Updated SampleRate: 44100 Distance: 0 09:46:02.121 T:529455404112 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding 09:46:02.123 T:529455404112 DEBUG: Minimum size we need for stream: 22656 09:46:02.123 T:529455404112 DEBUG: Created Audiotrackbuffer with playing time of 128.435374 ms min buffer size: 45312 bytes 09:46:02.132 T:529455404112 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 45312 m_frames: 2832 m_frameSize: 8 channels: 2 09:46:02.132 T:529455404112 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized: 09:46:02.132 T:529455404112 DEBUG: Output Device : android 09:46:02.133 T:529455404112 DEBUG: Sample Rate : 44100 09:46:02.133 T:529455404112 DEBUG: Sample Format : AE_FMT_FLOAT 09:46:02.133 T:529455404112 DEBUG: Channel Count : 2 09:46:02.133 T:529455404112 DEBUG: Channel Layout: FL,FR 09:46:02.133 T:529455404112 DEBUG: Frames : 2832 09:46:02.133 T:529455404112 DEBUG: Frame Size : 8
* cannot change the audio device - it is grayed out audiotrack
* channels: 2.0 (does not matter for the test)
* Passthrough - YES
* ALL audio formats - SUPPORTED (because my receiver can support them).
So, now I open test-file with simple AC3 sound (you can download the BigBuckBunny 1080p 60fps with AC3/MP3 audio from web) - it does actually not matter what file I select (with DolbyD, DolbyD+, DolbyTrueHD/Atmos, DTS, DTS-HD/HA), the result is the same always...
In the log I see Kodi has determined the file correctly:
Code:09:46:19.437 T:529396380752 DEBUG: Open - probing detected format [mov,mp4,m4a,3gp,3g2,mj2] 09:46:19.488 T:529396380752 DEBUG: Open - avformat_find_stream_info starting 09:46:19.548 T:529396380752 DEBUG: Open - av_find_stream_info finished 09:46:19.548 T:529396380752 INFO: ffmpeg[7B427BB450]: Input #0, mov,mp4,m4a,3gp,3g2,mj2, /storage/EE00A4EA00A4BACB/bbb_sunflower_1080p_60fps_normal.mp': 09:46:19.548 T:529396380752 INFO: ffmpeg[7B427BB450]: Metadata: 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: major_brand : isom 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: minor_version : 1 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: compatible_brands: isomavc1 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: creation_time : 2013-12-16 17:59:32 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: title : Big Buck Bunny, Sunflower version 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: artist : Blender Foundation 2008, Janus Bager Kristensen 2013 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: comment : Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: genre : Animation 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: composer : Sacha Goedegebure 09:46:19.549 T:529396380752 INFO: ffmpeg[7B427BB450]: Duration: 00:10:34.53, start: 0.000000, bitrate: 4486 kb/s 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 4001 kb/s, 60 fps, 60 tbr, 60k tbn, 120 tbc (default) 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: Metadata: 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: creation_time : 2013-12-16 17:59:32 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: handler_name : GPAC ISO Video Handler 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: Stream #0:1(und): Audio: mp3 (mp4a / 0x6134706D), 48000 Hz, stereo, s16p, 160 kb/s (default) 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: Metadata: 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: creation_time : 2013-12-16 17:59:37 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: handler_name : GPAC ISO Audio Handler 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: Stream #0:2(und): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 320 kb/s (default) 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: Metadata: 09:46:19.550 T:529396380752 INFO: ffmpeg[7B427BB450]: creation_time : 2013-12-16 17:59:37 09:46:19.551 T:529396380752 INFO: ffmpeg[7B427BB450]: handler_name : GPAC ISO Audio Handler 09:46:19.551 T:529396380752 INFO: ffmpeg[7B427BB450]: Side data: 09:46:19.551 T:529396380752 INFO: ffmpeg[7B427BB450]: audio service type: main
Code:09:46:19.711 T:529253160016 DEBUG: CDVDAudio::Pause - pausing audio stream 09:46:19.711 T:529253160016 INFO: CAEStreamParser::SyncAC3 - AC3 stream detected (6 channels, 48000Hz) 09:46:19.711 T:529253160016 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, pass-through) 09:46:19.712 T:529253160016 DEBUG: CVideoPlayerAudio:: synctype set to 0: clock feedback 09:46:19.715 T:529822999632 DEBUG: Keyboard: scancode: 0x42, sym: 0x000d, unicode: 0x000a, modifier: 0x0 09:46:19.718 T:529287455824 DEBUG: CDVDVideoCodecAndroidMediaCodec::Decode current state (2) 09:46:19.730 T:529455404112 INFO: CActiveAESink::OpenSink - initialize sink 09:46:19.730 T:529455404112 DEBUG: Draining Audio 09:46:19.732 T:529455404112 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack 09:46:19.733 T:529455404112 DEBUG: CAESinkAUDIOTRACK::Initialize requested: sampleRate 48000; format: AE_FMT_RAW; channels: 2 09:46:19.733 T:529455404112 DEBUG: Updated SampleRate: 32000 Distance: 144000 09:46:19.733 T:529455404112 DEBUG: Updated SampleRate: 44100 Distance: 35100 09:46:19.733 T:529455404112 DEBUG: Updated SampleRate: 48000 Distance: 0 09:46:19.733 T:529455404112 NOTICE: Trying to open: 48000 samplerate 12 channelMask 13 encoding 09:46:19.734 T:529455404112 DEBUG: Minimum size we need for stream: 12312 09:46:19.734 T:529455404112 DEBUG: Created Audiotrackbuffer with playing time of 128.250000 ms min buffer size: 24624 bytes 09:46:19.734 T:529287455824 DEBUG: CDVDVideoCodecAndroidMediaCodec::Decode current state (2) 09:46:19.739 T:529455404112 [COLOR=#FF0000]ERROR: AESinkAUDIOTRACK - Unable to create AudioTrack[/COLOR] 09:46:19.740 T:529455404112 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack 09:46:19.740 T:529455404112 DEBUG: CAESinkAUDIOTRACK::Initialize requested: sampleRate 48000; format: AE_FMT_RAW; channels: 2 09:46:19.740 T:529455404112 DEBUG: Updated SampleRate: 32000 Distance: 144000 09:46:19.740 T:529455404112 DEBUG: Updated SampleRate: 44100 Distance: 35100 09:46:19.740 T:529455404112 DEBUG: Updated SampleRate: 48000 Distance: 0 09:46:19.740 T:529455404112 NOTICE: Trying to open: 48000 samplerate 12 channelMask 13 encoding 09:46:19.741 T:529455404112 DEBUG: Minimum size we need for stream: 12312 09:46:19.741 T:529455404112 DEBUG: Created Audiotrackbuffer with playing time of 128.250000 ms min buffer size: 24624 bytes 09:46:19.745 T:529455404112 [COLOR=#FF0000]ERROR: AESinkAUDIOTRACK - Unable to create AudioTrack[/COLOR] 09:46:19.746 T:529455404112 DEBUG: CActiveAESink::OpenSink - open NULL sink 09:46:19.746 T:529328452688 DEBUG: Thread AESinkNull start, auto delete: false 09:46:19.746 T:529328452688 DEBUG: CAESinkNULL::Process 09:46:19.747 T:529455404112 DEBUG: CActiveAESink::OpenSink - NULL Initialized: 09:46:19.747 T:529455404112 DEBUG: Output Device : android 09:46:19.747 T:529455404112 DEBUG: Sample Rate : 48000 09:46:19.747 T:529455404112 DEBUG: Sample Format : AE_FMT_S16NE 09:46:19.747 T:529455404112 DEBUG: Channel Count : 2 09:46:19.747 T:529455404112 DEBUG: Channel Layout: RAW,RAW 09:46:19.747 T:529455404112 DEBUG: Frames : 12000 09:46:19.747 T:529455404112 DEBUG: Frame Size : 4
Same kind of thing happens to all passthrough audio formats and the same thing happens to SPMC17a10.
FTMC plays AC3 and DTS, no HD in there. But it is Jarvis-based, so the audio is handled differently, therefore it does not count. If there is FTMC17 beta/alfa somewhere, I'm happy to try this one...
I have not tried "shitty" Kodi versions, but it does not matter actually...
Because I did install "stock" image from this forum (aml_7.1_s912_q9377-H96PROPLUS_KDMC_mac-20170809.img) and passthrough works OK on this - I get DolbyDigital 5.1, I get DolbyD+ 5.1 and 7.1, I get DolbyTrueHD 7.1, I get DTS 5.1, I get DTS-HD 7.1.
And of course - running LibreELEC from SD works perfectly regarding passthrough and on videocodec...
So, the box is capable of passing through the audio, but there seems to be a glitch in FW.
I have indeed rooted the box, so, if there is a "simple fix" (permissions, settings, etc) that I can try, just let me know and I can try...
And I have tried the non-ATV version (SCV4 and so on) also - the same happens there.
Actually I even tried SCV2 beta (plus SCV3 OTA) and at least AC3 and DTS were passed through - I do not remember about DTS-HD, but this one might not play...
So, any advice would be good...
Just what ive been waiting for.
Can someone clarify the installation process for me. I cannot use the USB Tool option, SD Burn Card maker works and ive used it in the past so i will install this way.
So, downloading SCV1 Img which i will use to install from via SD Card.
I now see there are two more files,SCV1A Fixed and SCV2. I presume these are updates. Not images so how do i install them?
Looked through the posts and flashing it via TWRP is the way to go.
Now, do i flash both files or just SCV2 (which i presume has the SCV1A fix).
Do i Stick them on a usb flash drive and install them from that in TWRP?????
Im downloading all 3 files now just incase.
Once you have SCV1 installed.
Hit home - so you are looking at the home page.
Then select the bottom row (which shows 3 icons, the second is wireless and the third is the app drawer.
click on the app drawer, then move along until you can select update.
Make sure you have an USB drive attached with both updates on it. ( You can do it with only 1 update at a time but with 3 boxes to update it meant I could do each in turn and just move onto the next).
Select update - local and point it to SCV1A then confirm.
After it's flashed and rebooted, repeat the process for SCV2.
This will take much longer to reboot.
There you go, all done.
First of all, thanks superceleron for your work!
I'm going to receive this wonderful box in the next days. I understood how this ROM must be installed but I'm wondering if this ROM has the brightness fix like the stock one.
If so, how do you suggest to root it? I never rooted an android tv box because the ROM I installed on them were already rooted.
Thanks in advance
Originally posted by Akirainblack View PostNope, it's included in the ZIP, you could however also install if from Gplay as it may allow you to update SuperSU without having to download a new ZIP.
Originally posted by SiAuSiPo View PostFirst of all - this is a superb image! Fantastic job superceleron! I love the speed, love the Youtube, I love the design, etc. Great job overall.
in the logs all is ok detecting, it only cant create the graph when it trys to play it hmm...
Can you try stock? 7.1.2 version.
i m8 do a test version, but not now.. i cant im already on other work and i need to finish that 1º or else i get lost....
There are currently 3311 users online. 0 members and 3311 guests.
