Abdel313
It's V5 don't know why they send me older one when I bought it on sale 2 weeks ago :/
Btw. can we jump to proper thread cuz that one is about firmware which is fine
http://freaktab.com/forum/tv-player-...y-h96-pro-plusLast edited by majkool; 30 May 2018, 10:43.
Originally posted by ch3mn3yUpdate app sometimes doesn't want to work. Just boot TWRP and flash it that way.
Sent from my GT-N8000 using Tapatalk
Originally posted by hcardoso483Hello mate I was trying to flash something on TWRP but it stops cuz it says that Android version is 5.1 obviously there is something wrong with the tape version I got is there another with this fixed
Hello all,
I have the same TV Box than ch3mn3y,ALFAWISE H96 Pro+ 3/32 (S32-V6) (2017/09/05)
I have below problem with usb burning tool V2.0.8 and 2.0.6 and 2.0.5
[17:27:06 652][HUB4-2][Inf]--Failure : 3, FailureMax : 3
[17:27:06 654][HUB4-2][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
[17:27:06 654][HUB4-2][Inf]--Close device handle 0x0000086c
[17:27:32 242][Global][Inf]--User select about menu
for reset or brick, i need to short pin 29&30
Can you help me?
I try different Rom and I have Windows 10
hi all,
I'm trying to flash my h96 green pcb from ROM SCV7A 7.1.2 to SCV4A-ATV 7.1.2 But i'm facing issues.
how it's not possible to use ubs tool burnig due to TWRP, this one tell me that:
invalid zip file format with an error installing zip file ....
I tried with multiple redownload zip file but always same error .
Any idea to solve ?
Any idea to solve ?
ach06 hcardoso483
Not with TWRP. You may update fro V1 to V4a (or V4 to V7a if Normal rom) with TWRP, but not from V7A to V4A (or other way). This two roms are not compatible with each other and even if they would not be each others updates.
Don't know why You cannot use Burning Tool. I didn't have problem when moving from ATV rom to Normal. It just worked. When flashing do You connect charger? Maybe this is the problem, as reset+charger launches recovery menu? Burning Tools shouldn't need the charger, power coming form PCs USB port is all it needs.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
[QUOTE=ch3mn3y;n730030]ach06 hcardoso483
Don't know why You cannot use Burning Tool. I didn't have problem when moving from ATV rom to Normal. It just worked. When flashing do You connect charger? Maybe this is the problem, as reset+charger launches recovery menu? Burning Tools shouldn't need the charger, power coming form PCs USB port is all it needs.[/QUOT
You right mate I just read a little more carefull when i first read it i assumed he mentioned the other way around the only way is like you say do it all over from the beginning, when I flashed using the USB tool i didn't connect the charger not pressed the reset button I got everything ready to flash not ticking the erase flash not erase bootloader press start plug USB and everything just worked but I am on the h96pro not + it's kinda similar
I understand. However before flashing V4A or V7A You have to flash the base rom (V1 or V4). And it may brick Your device as it's not for pro, but Pro+ rom. It even bricks some variants of Plus, so I wouldn't try it with Pro.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 2447 users online. 0 members and 2447 guests.
