If it is transported by the water than You have to have it faster than me (Poland, Germany) :P However I should be better if it's coming by the train.
Still, ~5 weeks is not that long I think.
But I'm glad You got it.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Hello everyone, I am new and I immediately ask for your help. I have a h96 pro + docooler with 2gb / 16gb updated to android 7.1 last firmware august 2017. There are several problems: very bad wi-fi connection, micro-shots of h265 movies and DTS-HD MA audio that just does not digest it. Can I update it with the superceleron firmware? Thank you
Check what Your settings says about size of RAM or install an app for that.
If it says that Your box have 3 GB of RAM than You may flash green image (coz V2.2 is green?), if there is only 2 GB, than do not flash it (if You don't know how to restore bricked Box).
ZUK Z2 Pro ✓ᵛᵉʳᶦᶠᶦᵉᵈ
I installed the new firmware. But I can not do the update: I formatted the sd I copied the file still zipped. I inserted the sd in the box I turned it on then I go on update from local but I get the warning that there is no card inserted. where am I wrong? Another thing like STMC does not have the Italian language? Thank you
lucabis
I would try flashing the update using TWRP, not the app (which should boot the TWRP by itself).
To boot to TWRP, power off the Box, disconnect power cord, push the reset button with pin, connect power (keep pushing), push for ~5 seconds. It will boot to TWRP. In TWRP You have to use mouse or air mouse as the remote doesn't work and it air mouse capabilities are very limited.
As for SMTC I'm not using it, so I won't be any help in that matter.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 1063 users online. 0 members and 1063 guests.
