    for installing this Rom i try many times and at last it's working but it's not stable alike S32V6
      Originally posted by Dep View Post
      Hi everybody,
      I am pretty new in this sport amd I am looking for some help,
      I paste my problem on several topics here but without any luck so far.
      Bought H96 pro plus Alfawise 3/32 from Gearbest about a month ago. Since then I am trying to find a ROM that will work without crashing, but without any luck.
      Is there anybody who can tell me which ROM is suitable for my box. It's green PCB ZH01-S912-TVBOX-V3.0.
      Thank you in advanced
      hello one of my friend receive same box of you it s model wisdom fabrication normaly that s write wisdom 2.2 on info kernel
        ok
          Originally posted by Abdel313 View Post
          hi ch3mn3y my box work with this rom
          I'll try thanks!
            As I mentioned before, I am a beginner so please explain me what does that mean.
            What should I do
            Thanks!
              in fact that s simple This model would have been manufactured by a different factory (Wisdom instead of Hcygood) by Gearbest. It is not impossible that other merchants are included in it. Which is rather banal in China.
              It is possible that some of its models have design problems: Abnormal heating, freeze / extinction after 2 hours of use ... These comments are followed by user feedback here and elsewhere, but others have no problems .
              The problem is known, besides some correct it with the help of a special Wisdom firmware here (src freaktab). Others simply update the box. For the rest, you can also return the box to Gearbest (ticket). Returns charges are at your expense but you can request a refund, as the problem is known.
              FOR ME on two box alfawise H96PRO + NO Prb hcygood
              my cousin receive yesterday the model wisdom and he try ota SCV4A ATV for superceleron and now it s bricked completly no connexion on usb burning tools
              and for the solution nand i don t find on this model the nand circuit for short pin in mask mode
                I see!
                  Someone with Wisdom box bricked after flashing superceleron's Rom restored my backup of stock (even when I have Hcygood Box I think, S32-V6) and it is back working.
                  ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
                    ah what is the procedure tecnic to take this because i repeat this box is bricked completly no connexion success with usb male male and usb burning tools
                    and i don t find nand chip on this pcb the photos is up
                      You would have to try if it boots to Recovery Mode, even better TWRP:
                      Copy this file to sdcard: https://mega.nz/#!Ji4iEAjI!5iCbS2F9J...cO6-MWb1b-z90I
                      Than boot device this way: disconnect power cord, start pushing reset button, connect power, push reset for 5+ seconds.
                      If it will boot TWRP, than You may be able to restore backup. Mine is here:
                        the box don t have blue light and no red light no connexion on usb burning tools i m not sure is boot in recovery mode
                        i try in few hours
                          Hi Abdel313 ,
                          Could you please explain in more detail how you got this rom working with the ZH01-S912-TVBOX-V3.0 version?
                          I just got this box and don't even have the stock ROM, maybe someone already got this from Gearbest or factory?
                          I will only experiment with this ROM if I know I can go back to a working ROM
                            Hi Msss81,
                            i use burn card maker with sv1 green pcb.
                            Push reset and plug the power cable.
                            i have do this a lot of times and the installation work.
                            When is done i have upgrade sv4a with trwp.
                            And at last i did the factory reset with trwp.
                            Now is working.
                              Hello ch3mn3y
                              for the box h96 PRO+ Fully bricked model wisdom 2.2
                              no led blue no red light
                              no connexion on usb burning tools no red light on spdif
                              i have info for the shorpin circuit possible
                              i have found this
                              i try this immediatly
                              but i see the firmware wisdom post here have problem with mac adress that s write on right panel MAC 0
                              It s necessary to modify the file ether.ini in directory of usb burning tools /license/
                              to write this :
                              mac_ether.ini file:
                              [Group1]
                              start = 78:c2:c0:91:57:99
                              end = 78:c2:c0:91:97:ff
                              used = 89
                              [fragment]
                              fragment =
