Is it fixable with a OTA update? (codec patch)
Originally posted by superceleron View PostIs a hw codec problem!
Can I disable the video hw acceleration by default on this rom if I have root access?
If someone wants to use Plex without audio/video decoding problems I suggesting to use PlexKodiConnect (not Plex for Kodi) with Kodi.
Plex integration in Kodi done right. Contribute to croneter/PlexKodiConnect development by creating an account on GitHub.
It will looks like Kodi but with the Plex videos. (movies and series are only shown in 2 folders )
HDMI-CEC is working like that the tv box is a tv.
E.g. if I turn my tv on the box turns on. (with normal android os it was the other way around)
But if I turn the box on the tv is not switching to the box hdmi port. (only after pushing the home button.)
Can this be solved or all android tv boxes are working this way?
Other question: Are there any solution/hack to use the tv box as a chromecast receiver?
Originally posted by Lacix View PostHDMI-CEC is working like that the tv box is a tv.
About Chromecast... dont get your hopes high, since it needs license's to work correctly ($$$), if someone hacked it dunno...
Don't have WhatsApp. Just upload it to YT or maybe Zippyshare?
However I'm not sure what;s Your problem. Have same variant and it's OK. I think I read that someone had to push the reset button for whole flash. Maybe try it?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
I have problems with this firmware now, and finally decided to switch back to my older box M8s MIIs edition with your similar firmware.
Problem is simply that most mkv's played have artefacts shown during playback, so video looks like a bad digital signal much too often during playback.
Any chance we will see a new update from 4A?
Originally posted by Lacix View PostAnybody else has problem with video playback?
Only good playback results (no pixelation/blocky picture) if hw acceleration is turned off in Kodi.
Sample file: https://drive.google.com/open?id=1W5...6KUgFEYu1v3I7H
On TV: https://drive.google.com/open?id=1yC...RPUfUB_mKN2Idn
I just got tired of this after some time, and i can confirm those issues ;(
Originally posted by ch3mn3y View PostDon't have WhatsApp. Just upload it to YT or maybe Zippyshare?
Will look later (my classes starting in a moment), maybe I'll find something.
However one thing: I use Burning Tool v2.1.2 (as said on the titlebar) or v2.0.7.2 (as said in About->Help) - it's same app. Maybe try this version?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by bilna View Posthello, I own AlfaWise H96 PRO + 3/32 with a green pcb. I did download SCV1 GREEN PCB IMG. Could you give the installation procedure?
should a USB cable or SD card is sufficient?
Thank you in advance for your help
I've followed this instruction:
I didn't see anything on my TV screen during installation after booting up with reset pressed but after long minutes it rebooted with the new firmware. So I advice you to be patient and wait 10 minutes before thinking something went wrong.
There are currently 6213 users online. 1 members and 6212 guests.
