Thank you for the great work superceleron just a few thoughts/questions:
- I don't see the sound volume being controled by the remote control, is it a problem of my box or Android Tv is like this?
- I've used before an USB stick and keyboard in order to type and use a mouse, I don't think this have the modules compiled to make it work, do you have the sources thar you can share of a valid Kernel so I can play around? (I found a packed file with keyboard HID modules, I will give it a try to fix this for me)
- I see why you have included FTMC, but it's not fully Kodi compatible, if I run wizards like "No Limits" will fail. Is there any newer version fully compatible with Kodi Krypton?
Thank you very much!
Originally posted by Lacix View PostAnyone uses Plex?
I don't have any sound in it. (either Dolby Digital AC3 or DTS)
Mediacenter player also has no sound playing from DLNA.
Youtube has sound.) Searching for a solution.
Other problem I have with my box is that the wifi speed has problems (with stock 7.1.1 the same issue before)
With a 390Mbit connection (2m from AC866 router) it only able to download max 30Mbit/s on TCP.
Anyone has the same issue or is it only a problem with my box? (used Tamosoft client-server test with a pc connected with LAN to router as server)You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
I've searched about it and see the plex issue is known. (I like the Android TV interface but on normal android I was able to use an external player for plex to make a workaround for this issue, The Android TV version don't have this setting) Searching for a solution.
Originally posted by temperdu View PostThanks !!! Feedback :
- SCV1 with USB Burning Tool : I've been afraid at the begining because the flashing process started but stalled at 7%. I tried on another USB port and it worked flawlessly.
- SCV4 by copying the whole zip file on a micro SD card, then install by TWRP. Dalvik cache reset then reboot. Fine.
Preliminary tests :
- Works perfectly with Plex
- Works perfectly with a HDHomerun (via Live TV as well)
So far so good, thanks !
THX
There are currently 3865 users online. 1 members and 3864 guests.
