Just read through a bunch of pages here and managed to unbrick my Wisdom version of this TV Box.
Any news on getting the ATV Rom to work on it? dies @ 7% in usb burning tool
Try with SD card method. It worked for me (the version for green PCB) by holding the reset button during the complete flash process. Thereafter install the SCV4 through TWRP.
I just bought the H96 Pro+ 3/32GG (S32-V6), but this ROM don´t seem to work for me. I flashed several times and used USB Burning Tool and also Burn Card Maker. The flashing process was ok with no errors, however when I connect the box, the TV is always black, although I can access the TWRP.
hello superceleron congratulations for this rom. I downloaded the scv1 rom on the front page, I installed it correctly. I inserted the scv4a zip in the sd card to update it, but when I go to do so the box goes off without then re-enter the recovery for the flash as if it were missing the twrp. where am I wrong? thank you
Hello. First i would like to say thank you for this great rom! :-) I have a question about the build-in Chromecast. I believe i read somewhere that it is not possible to get it to work.. so my question is... is it possible to completly disable it somewhere in the settings? It is a bit annoying that the "Chromecast screen" shows up while a videofile is paused ( during a phonecall ect.)
Thanks in advance :-)
[QUOTE=ch3mn3y;709763]peppuzz
Did You try to boot to TWRP manually?
Or use image placed on SDcard.
I tried to restart in recovery but also in that case it goes off. while I do not have the image of the twrp to put in the sd card, could you kindly tell me where I can find it? then I have to flash it using the reset button? thank you
It's inside the zip files with updates of superceleron's roms (it's in base images too, but it's easier to open archive file than image).
Or here: https://mega.nz/#!Ji4iEAjI!5iCbS2F9J...cO6-MWb1b-z90I
It's same one I unpacked for myself. It works, tested with stock as now I have working TWRP flashed to it's partition on eMMC (that's why I'm not sure why You don't).
Just installed sucessfully SCV1 on my box. Now im trying to update to SCV4A with recovery (im using a USB pen with the update file) but when i enter in recovery mode, TWRP window ask me to swipe to allow modifications. How do I swipe?? Ive tryed a lot of combinations with remote control keys but nothing... How can i swipe or continue with the update process?
You need an airmouse or regular mouse connected to the box to swipe/drag the button.
