Thanks for the great rom.
A bit confused by the instruction:
INSTALL 1º SCV1 IMG AND THEM BY RECOVERY TO SCV4A!!
So after flash the SCV1 rom using usb burning tool, I'll flash the SCV4A update via OTA (local)?
Or flash the SCV4A update via going to recovery mode?
Thanks.H96 Pro+ 3/16 (CZ-S32-V3(DDR4) Green PCB) | 7.1.2 | SCV4A Android TV | TWRP 3.1|
Originally posted by ch3mn3y View PostDoesn't matter. Update app will reboot to TWRP and flash the SCV4A. So it will be the same as if You manually boot the TWRP and flash zip.
My board is CZ-S32-V3(DDR4) 3G RAM 16G Flash,
so I will use the green pcb img right?
Edit:
Yes, the green pcb img works very well, impressive.H96 Pro+ 3/16 (CZ-S32-V3(DDR4) Green PCB) | 7.1.2 | SCV4A Android TV | TWRP 3.1|
Is there a way to pull up all apps to force close apps other than thru settings? I know with android tv I would usually double click the home button. But with this I havent been able to do that. I've used the android tv version for my beelink and it works no prob. Any help would be great thanks!
I'm talking about the recent apps button to force close apps running in the background. In android tv you can usually double click the home button and you get your list of apps running and close them. When I press the recent apps button on my keyboard the pop up but I can't close any of the apps. It just opens up the next app in the line up.
I'd like to report some external storage issue here.
I have a 120GB USB 3.0 external harddrive, with three partitions (recovery, EFI and a large NTFS system partiton, was a windows 10 OS drive),
It seems this hardrive can not work properly on this tv box with SCV4A.
It recognized the external harddrive, but only showing one partition with 1.3G capacity, and it's not acccessible.
Changed external enclosure to use different chipset, but still the same problem.H96 Pro+ 3/16 (CZ-S32-V3(DDR4) Green PCB) | 7.1.2 | SCV4A Android TV | TWRP 3.1|
I wouldn't say it's a bug. It's just the way Android is handling external storage. Similar to Windows, so it shows only first partition. You have two ways to see whole available memory:- reformatt drive with 1 partition,
- manually mount other partitions.
ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3y View PostI wouldn't say it's a bug. It's just the way Android is handling external storage. Similar to Windows, so it shows only first partition. You have two ways to see whole available memory:- reformatt drive with 1 partition,
but it's showing as 1.3GB in Total Commander and it is not accessible.
It is not showing in file manager at all.H96 Pro+ 3/16 (CZ-S32-V3(DDR4) Green PCB) | 7.1.2 | SCV4A Android TV | TWRP 3.1|
There are currently 2732 users online. 0 members and 2732 guests.
