the mouse connect it to a usb port?
If You want to create backup than there will be tile with "Backup", than You have to check all partitions and move the slider.
It's good to make one, as if something happen, You will be able to restore working soft.
For Installation, there is a tile named "Install", after clicking it You will se some kind of File Manager where You will have to look for .zip file. After clicking the .zip, move the slider and wait till it will be flashed.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
No idea. I heard about Error 1 with MAGISK, but not with rom updates...
No idea what is the problem, but maybe TWRP was wrongly flashed? Copy this file onto Your SDcard: https://mega.nz/#!Ji4iEAjI!5iCbS2F9J...cO6-MWb1b-z90I
Than boot with pin and reset button. It's image of TWRP from SCV7A. Maybe it will work?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
If we are talking about THIS rom, than there is no SCV7A. They are two different roms
- this one is Android TV and here is V1 image and V4A as update:
- the other one is Normal Android and there is V4 image and V7A OTA.
They are not compatible which each other.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 2448 users online. 0 members and 2448 guests.
