Originally posted by ebabilonia View PostI disable chrome. and enable Android System WebView. Upload youtube video how to fine Android System WebView
I advise you to do a backup with TWRP before making any sensible changes. Are you going to try to update to scv7a As advice x92-2GB ?
Originally posted by ebabilonia View PostI disable chrome. and enable Android System WebView. Upload youtube video how to fine Android System WebView. you can fine chrome in the same list of applications.
Originally posted by Morgan5000 View Post
Just a question internet browser Always working ? Vidéo on a internet browser ? Bad on a scv1 ! I use browser Samsung best browser for me on this rom!
I not try video in browser. But i think is work because some app i use is base in website video. I will keep with this rom scv4a. Everything i use work with this rom.
Originally posted by Lacix View PostCould anyone upload the build.prop file?
I may messed up mine and my box is disconnecting regularly and can be only fixed with turning the wifi off and on again.
With wifi 2.4 GHz or 5ghz ? Me 5 GHz somethimes Bad working. Or maybe test change GHz Channel on router before change buid.prop
One can set the device local to ALL, and wifi channels to 13.
Originally posted by X92-2GB View Post
If box is located in the EU, his build.prop will need to be set appropriately. Had that problem with a tablet that worked fine in the US and UK, but once I got to the EU, device would not connect properly.
I flash yesterday and yes my live tv app crash.
To fix first need to disable chrome. The check is Android System WebView is enable and update with play store.
Now Staker, pix and mitv+ work perfectly.
To make it clear, you have to add under \system\priv-app\TV\lib\arm\ the file libtunertvinput_jni.so
Just to let you know... adding some Google system apps and missing libs has helped. I am able to use all the active channels options and add more channels from play store. Many report issues with active channels.
also I did note in my cat logs, that the two new updated phone apps failing are with the missing priv-app/TV/lib/arm lib file. So I will add the missing folders and files required to correct the error.
seems like just by the small corrections I have made, and my tweaked and customised build.prop, phone apps are 95% compatible and TV apps are about 100% compatible outside of the latest YouTube and YouTube TV.
For some reason Chrome browser helps make the compatibility better than Web view, but i still don't understand why others report differently. Seems that there must be something that may be build.prop oriented with mine. I could post mine for reference, it is very big on enhancements pertaining to ATV options and functionality.
There are currently 1530 users online. 1 members and 1529 guests.
