Originally posted by ebabilonia View Post
Originally posted by X92-2GB View PostDid not stay on SCV4 on my box. Moved on to SCV7a, updated chrome and system files, the only issue is that 3 newer versions of mobile streaming apps crash. Nat Geo (US only), STV (Scotland) player, and SBS on Demand (AU). IMO Webview is not as good as Chrome. Just need to make sure your Chrome and Play services are updated regularly.
http://freaktab.com/forum/tv-player-...7-wifi-chipset
Originally posted by Morgan5000 View Post
For the last time X92-2GB This topic treats SCV1 and scv4a that are not scv4 and scv7a... These are two different ROMs. Here is the topic of the Rom scv4 scv7a
What ze fuhk! I mentioned a possible fix, so I am only to sat my fix works on SCV7a? Hella no! It works on most firmwares than may need it. So who are you???
I think we understand each other badly x92-2GB I have absolutely nothing against you but you have to understand that these are two different ROM.
It's not after reinstalling applications that caused the crash but reinstalling the 5min system before reinstalling everything was working now everything works under SCV1 only known bugs. You say that currently just disable the Google Chrome browser and update the Google services and Play store for resolved problèm applications crash ? I looked under SCV1 in the list of applications but I can not find Web service view it is integrated chrome maybe?
Why go around undoing what Google has done with Android 7. There is a reason why webview is disabled, and chrome is enabled.
your being a hard arse, who Is comparing apples and oranges? Both are Android TV. Just one is more improved.
like I said, I rand SCV4 and found SCV7 a better base for improvement on ATV. It is less problematic and stable with my box. Just pointing out minor things to keep updated.
If both of you guys would read through SCV7 and you would find out it is an Android TV update. You can probably run it as an OTA over SCV4, just backup everything if you should have a problem.
Originally posted by X92-2GB View PostWhy go around undoing what Google has done with Android 7. There is a reason why webview is disabled, and chrome is enabled.
I enable and update Android System WebView in the rom SCV4A. Is in system App. I don't know is the rom SCV7a is a Android TV Version.Last edited by Morgan5000; 28 August 2018, 19:36.
Can you put a photo of the location where you activate Web view??? Non scv7a is Android similar to the Tablet smartphone version besides it has the same Play Store scv4a is actually Android TV like Asus Nexus player or new smart-TV with Android or NVIDIA Shield so designed exclusively for TV scv7a has just a TV launcher But is not Android TV even if you pin the box has a TV
as for your other info, you are wrong. SCV7a is android TV. Just the build.prop is kept from SCV1a as a phone os. To make the build.prop right, just copy or edit it to reflect a mibox, from your SCV4a.
As for enabling Webview, un install chrome. Webview is disabled by chrome being installed.
You say that the update scv4a to scv7a is quite possible but that it is necessary to copy the build. Prop of SCV4A and replace it in scv7a After update.
Originally posted by ebabilonia View PostI not home but tonight i will include the screenshot for Webview. Maybe the difference of time. I'm from Caribean
There are currently 3243 users online. 1 members and 3242 guests.
