Sent from my M9 pro using Tapatalk 4
Pipo M9 Pro RileyROM 1.2 (M9 with 1920x1200 display) [Feedback]
New firmware seems smooth and responsive. WiFi good though unlike some I had not experienced reception problems to me honest. I was hoping for improvements in GPS but not it still really slow to lock on and doesn't stay connected. Does come with multi window. I rooted and added cwm and no problems there, would like to increase parameter for internal memory from 2gb to 8 using rileyrom parameters but not sure if or how I can do that. Not used if I able just to flash the 8gb parameter directly to my installed promising tool rileyrom provides or if I need to install the full rileyrom
Originally posted by davesmall View PostNew firmware seems smooth and responsive. WiFi good though unlike some I had not experienced reception problems to me honest. I was hoping for improvements in GPS but not it still really slow to lock on and doesn't stay connected. Does come with multi window. I rooted and added cwm and no problems there, would like to increase parameter for internal memory from 2gb to 8 using rileyrom parameters but not sure if or how I can do that. Not used if I able just to flash the 8gb parameter directly to my installed promising tool rileyrom provides or if I need to install the full rileyrom
I'm downloading, too...and yes it is very slow.
Stay tuned for a new RileyROM...hopefully sometime today!!!!!!!Randy
Re: Pipo M9 Pro RileyROM 1.2 (M9 with 1920x1200 display) [Feedback]
Originally posted by rrileypm View PostI'm downloading, too...and yes it is very slow.
Originally posted by davesmall View PostAnyone know if you can use rileyrom parameters and flash to just to change parameters and not install all the other files. I did it for the cwmrecovery and it worked great on my already installed rooted rom
Changing the parameter requires all components within the ROM to be reflashed. That's why you can't use CWM to flash a new ROM with a different set of parameters.
All of the files/partitions have to move to new locations within NAND.Randy
i have update with new firrware 22/08/2013 (english, cleaned, rooted, with app space 4gb and optimized version available on arctablet? i don't know if i can say it but sorry for freaktab).
I'm very happy
Wifi is very very good and now i can see my 3 wifi (only one before)
Tablet is really more responsive and fluid.
All seems work very well and better that before.
FINALLY
I go to test it more
I really like, randy can make his rom like usually form this new update for us.
Originally posted by nicaise View Posti have update with new firrware 22/08/2013 (english, cleaned, rooted, with app space 4gb and optimized version available on arctablet? i don't know if i can say it but sorry for freaktab).
I'm very happy
FINALLY
I'm almost done downloading the new firmware.
Stay tuned. You'll get a new RileyROM sometime today.Randy
RileyROM v1.3 is out!!!!!!!!!
Randy
Are you talking about v1.2 or v1.3?
RandyRandy
There are currently 2072 users online. 1 members and 2071 guests.
