New H96 Pro+ bricked itself after a couple of hours use. Help me diagnose / rescue, is the hardware dead?
    Hello. I installed TEST VERSION and OTA-SCV7A-A7.1.2-x64-Alfawise.H96.ProPlus.zip. Everything works fine.
    thank you very much
      Kindly please someone describe the process clearly step by step for a newbie like me. Please....as I'm fed up with this bricked box
        can someone tell me what that error mean?i'm trying to flash the test firmware but always the same error but not in the same percentage!!!
        edit:false alarm!!!change the usb cable with another that i made and succesfully burned...now im going to update with OTA-SCV7A-A7.1.2-x64-Alfawise.H96.ProPlus.zip and waiting teh ATV version...thanks to all...
          thank you very much
          Please write us more details (describe steps analytically) how you managed to burn test FW and unbrick the box. I'm trying all the time but can't even burn the FW (always stops at 2% with message '0x10105004 Romcode/Initialize DDR/Read initialize status/Error result'
            Originally posted by svionut View Post
            Hi I installed your test version, then I successfully updated to the latest OTA . Everything is fine. I finally debricked my box. I added also the serial log. Thanks a lot superceleron and AndyMarty80
              thank you very much
              Hello
              The flash with TEST VERSION is OK. But, how do you do, to flash OTA-SCV7A-A7.1.2-x64-Alfawise.H96.ProPlus.zip ?
              Can we explain me ?
              Thank's
              Bye
                Originally posted by mirage47 View Post
                Hello
                Can we explain me ?
                Thank's
                Bye
                  Post the error.... These boxes hard to totally brick possible yes.
                  You need to make sure driver and burn program installed correctly. Then download the correct firmware. Had some flashing device with firmware for completly different chipset. More you post better someone can help you. Photos of board also help. Wifi chip.... Ect ect.
                    Sorry
                    but with TEST VERSION, you can't have message error at 2%.
                    A 4% process stop, Yon unplug usb cable and you re-plug the USB cable . The process continue a 100%
                    Good luck
                    Bye
                      Yes but when usb burning tool can't see the box anymore, it's dead. Right ?
                        YES...or no !!!
                        Re-install the driver in folder C:\Program Files (x86)\Amlogic\USB_Burning_Tool\WorldCup_Device.
                        Use the last version of soft V2.1.2
                        You must plug and unplug every time to see CONNECT
                        You plug USB cable
                        You switch on RESET
                        You plug power
                        You swith off reset
                        You can see CONNECT
                        Are you sure of your USB MALE to MALE ?
                        Do you earth the sound when you plug usb on your computer like to USB KEY ?
                        Bye
                          Originally posted by AndyMarty80 View Post
                          Success my friend! I tried the firmware in the link, the one named aml_7.1.2_s912_q9377-H96PROPLUS_LP_KDMC_mac-20171010(warning).rar in the H96 Pro+ Firmware (Hcygood) folder, and I succeeded to flash it (ignore the errors and disconnects, it will flash 100%). And I just booted it!.
                          I flashed with the 2.08 version of the burning tool. Let me know if you succeed too
                          superceleron Would it be possible to make your firmware compatible with LPDDR3 devices too please?
                          Can't find the exact filename in the link you posted. Any advice for alternative source?
                            Hi these errors at 2 percent are usualy because of writting of wrong firmware (wrong driver for dd-ram). That test firmware made by celeron is only for h96 pro plus S32-V5(LPDDR3) box. First of all you need to know what box do you have. You can connect a serial cable if you want to see the logs from the box. If I were in your place, I would try all the firmwares from this link:
                            https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!pjRnUKBK
                            Maybe you have luck and find the correct one.
                            Here are the steps of writting with the burning tool:
                            http://freaktab.com/forum/tv-player-...o-any-s912-rom
                            You can find here how to connect the serial console (post 9):
                            http://freaktab.com/forum/tv-player-...bricked-solved
                            Info about bootloader:
                            http://freaktab.com/forum/tv-player-...icked-your-box
                            If you erased bootloader you can only unbrick with usb burning tool. If your bootloader is still intact you can use also Burn card maker to unbrick your box.
                            https://www.duiadns.net
                              YES...or no !!!
                              You plug USB cable
                              You switch on RESET
                              You plug power
                              You swith off reset
                              You can see CONNECT
                              Bye
                              Thx for your help
                              I have no sound When I plug usb to my computer.
                              I can not find a valid link for usb burning tool v2.1.2. This one is corrupted https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!d3JyiSaA
                                It is possible that a recent Windowa update wiped out the drivers and need to make sure box in connected with the burning tool and then run WorldCup_Device and reinstall the drivers.
