New H96 Pro+ bricked itself after a couple of hours use. Help me diagnose / rescue, is the hardware dead?
And what about the board name? Unfortunately most H96 Pro Plus are DDR3, but it doesn't make their firmwares compatible...
Originally posted by MIKermit View PostAlso I couldnt find the pins but the reset button worked fine and I managed to flash it.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by ch3mn3yAnd what about the board name? Unfortunately most H96 Pro Plus are DDR3, but it doesn't make their firmwares compatible...
Does it work or not? If yes, and if You could check board name, maybe it would help other confused users in the future.
It works, but as I mentioned some posts above, It freezes and wifi or Bluetooth or both of them, doesnt work and crashes. It works only after 3-4 plug and uplug the charger.
Στάλθηκε από το BLA-L29 μου χρησιμοποιώντας Tapatalk
Originally posted by maxim33 View Post
Hey Guy, as suggested earlier , you must replace your power adopter and all of your problems will be gone . Because most of the power adopters come along the box are creepy and they didnt provide full juice to the box ,and that lack of power causes frequent hangs and crashes.
So you think its not the firmware, its just the power adapter? Do you have a link for a test adapter to buy?
OK thanks...
superceleron
Oops
The excellent version was well done, But I needed a version of Marchemelo how I could find a version that was compatible with the LPDDR3
S32-V5(LPDDR3)
amlogic s912
Ram 3 LPDDR3
ROM 32
q9377
I have the H96 Pro since sept 2017 and was working fine till 3 months ago.
The unit does not power up, red or blue light keep on blinking till I plug a new adopter.
Since then I have bought 3 new power adopters.
Somehow the power adopters do not last more then few weeks, voltages output is correct 5V, but I think the amperage is not there anymore.
Customer service from China sucks.
Any idea why the power adopters fail. The last one bought is 5V 3A. Hope it will last longer.
Originally posted by Ova View PostI have the H96 Pro since sept 2017 and was working fine till 3 months ago.
The dreaded "S32-v5(LPDDR3) 2017-08-29"
What a pita !
Change the adaptor and stick with superceleron's roms!
There are currently 2596 users online. 0 members and 2596 guests.
