New H96 Pro+ bricked itself after a couple of hours use. Help me diagnose / rescue, is the hardware dead?
Originally posted by AndyMarty80 View PostSo, I just tried your test rom. I unchecked erase bootloader, kept erase flash, normal erase.
I initially got an error at 1%: 10101002 Romcode/initialize ddr/identify/usb control setup. And it disconnected the device. I unplugged and replugged it, process continued until complete. First boot took a long time, but it works!
Yay! Thank you.
Can I update to the latest version of that ROM or you need to prepare a special one too?
What about the Android TV one? (that's actually the one I want to install). Thank you so much!
Originally posted by svionut View Post
Hi these errors at 2 percent are usualy because of writting of wrong firmware (wrong driver for dd-ram). That test firmware made by celeron is only for h96 pro plus S32-V5(LPDDR3) box. First of all you need to know what box do you have. You can connect a serial cable if you want to see the logs from the box. If I were in your place, I would try all the firmwares from this link:
https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!pjRnUKBK
Maybe you have luck and find the correct one.
Here are the steps of writting with the burning tool:
http://freaktab.com/forum/tv-player-...o-any-s912-rom
You can find here how to connect the serial console (post 9):
http://freaktab.com/forum/tv-player-...bricked-solved
Info about bootloader:
http://freaktab.com/forum/tv-player-...icked-your-box
If you erased bootloader you can only unbrick with usb burning tool. If your bootloader is still intact you can use also Burn card maker to unbrick your box.
Originally posted by strogilow View Post
Thank you for all info you wrote above. I finally managed to complete with success the burning of test FW (i left unclicked the erase bootloader option)- but still can;t boot. Don't know why?
When i bricked my device i had this checked and i was able to recover it. If you are able to write with usb burning tool you can write the bootloader.
You could try with bootloader erase option checked.
It's really very strange. I have managed to write the correct stock FW with USB Burning tool (I have received a complete 100% successful message) but the the box does not boot. The last thing I have not checked is to replace the power supply adapter (just in case there is a kind of problem with this component). I have no other choice.
https://www.aliexpress.com/item/1PCS...311.0.0.rLrurl
Also my power source is already broken. I powered the box by using the second usb connector with an 5V/3A adapter.
You could try also with force erase or force erase all option checked.
Originally posted by mirage47 View Post
YES...or no !!!
Re-install the driver in folder C:\Program Files (x86)\Amlogic\USB_Burning_Tool\WorldCup_Device.
Use the last version of soft V2.1.2
You must plug and unplug every time to see CONNECT
You plug USB cable
You switch on RESET
You plug power
You swith off reset
You can see CONNECT
Are you sure of your USB MALE to MALE ?
Do you earth the sound when you plug usb on your computer like to USB KEY ?
Bye
Originally posted by Oops View PostI followed your steps. Nothing does it. Still not detection of the box by the pc. It's definitely dead. Thx for your help.
Also you could try to connect the serial and you will see if is really dead.
You need a pl2303 Usb to rs 232 converter. You can buy one from:
https://www.aliexpress.com/item/pl23...9-c1b60909649b
Also you can find this on amazon, just search pl2303.
The serial pins are between the 2 usb. If you look in first picture from post 9 you can find that at triangle sign is the black wire, then yellow, blue and red. If you magnify the second picture also from post 9, and look at connection to pl2303 you'll find that:
- black is GND
- yellow is RX
- blue is TX
- red is VCC 5V
After connecting these wires, you need to start putty. You can find it here:
https://www.chiark.greenend.org.uk/~...ty/latest.html
You can configure it like in the attached picture, just need to replace COM1 with the COM detected by windows for your pl2303 converter. Just go to device manager and find the correct one.
Start it then press reset on your box. You should see:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0;POC:3;RCY:0; EMMC:0;READ:0;CHK:AA;SD:0;READ:0;CHK:AA;USB:8;0.0;
on your putty screen.
The power source is very bad. I already ordered this:
There are currently 1942 users online. 0 members and 1942 guests.
