rk3229 android 7.1 firmware(wifi 8703)
    KingboxRK-8703-7.1nv3-Kodi-1225: (Kingbox K1, K1 plus, K2, but not for Kingbox K3!)
    https://mega.nz/#!w2BXFbhQ!lpW2_C9W1...2M0FCzzNWf0o8I
    LeelboxRK-8703-7.1nv3-Kodi-1225: (Available to shell model is t95d MXQ PRO, MXQ MINI, Q2 pro, Q2 mini, Q1)
    https://mega.nz/#!wrwyXYxD!0q0yVDFfT...FRiFYl_mUkVbTE
    Who can help me make a mod for R Box rk3229(wifi 8723bs)?.Thank you very much.
    Thanks for this, Leelbox version confirmed working with both IR and WIFI on V88 RK3229 with 1GB and SV6051 chipset.
    Where did you find these firmwares? Thanks
      I try both firmwares with my v88 1/8G (spdif & AV ports orange) (firmwares with bootloader 2.31 working on it).
      Wifi working but remote not.
      pre-rooted but ask for update binaries on SuperSU and don't working (update and root)
      any solution ?
        any solution ?
        Ok thanks... it works 100% on the V88 I have but this one is black ports
        I have not figured out how these damn rockchip roms control the remote configuration beyond just the layout, does not seem as simple as just moving a conf file around like with amlogic roms to fix compatibility.
        Here are the remote keylayout (.kl) files for IR remotes from a working V88 rom, from system/usr/keylayout. not sure if swapping these will fix it...
          Tried upgrading with leelbox, said successful but now my mxq won't power up and there are no lights what so ever.
          can anyone help?
            can anyone help?
            You will need to open the box then unbrick it by holding reset, shorting two pins on the eeprom chip, before inserting the USB cable into the OTG USB port. There are other posts in this forum on which pins to short, you can hold a pin or mini screwdriver or whatever to momentarily short the pins.
            If do it right then Android Tool or Factory Tool should show a MASKROM device connected. You can flash from there.
              cheers, will give it go
                Did you get the remote to work on v88?
                  Works fine on my MXQ Pro 4K only one button is changed
                    Anyone know how to fix the remote control? This is a great rom , but the ir remote stop working. Click image for larger version
ID:	705994Click image for larger version
ID:	705993Click image for larger version
                      you can buy one remote with usb dongle, like this https://www.geekbuying.com/item/M10-...te-375180.html if there is no software solution
                        I have a V88 box and managed to flash the Leelbox successfully. The problem is my remote is not working anymore. Any solution?
                          Selam arkadaşlar. Bu rom MK809İV RK3229 RTL8703AS için uyumlu mu?
                            Hi anyone have a solution? or could you at least tell me how to start solving the, ir remote control bug?
                              Hi friend, What is the remote control of your TV box?
                              I saw that the kingbox k1 is practically identical to my box a95x of the photos above, I tried with the rom of the leelbox and it went without remote control, I'm going to test the one of k1.
                              Last edited by Evandrotfg; 08 February 2018, 03:01. Reason: I saw that the kingbox k1 is practically identical to my box a95x of the photos above, I tried with the rom of the leelbox and it went without remote control, I'm going to test the one of k1.
