rk3229 android 7.1 firmware(wifi 8703)
Originally posted by manu_manu4 View PostI try both firmwares with my v88 1/8G (spdif & AV ports orange) (firmwares with bootloader 2.31 working on it).
Wifi working but remote not.
pre-rooted but ask for update binaries on SuperSU and don't working (update and root)
any solution ?
https://mega.nz/#!jYojUATK!8u7QdtWI-...93GQzAHP7zuUvE
rk3229_7.1_MX4VB_SSV6051p_ v88
then root it with this tutorial ( Excuse my english but I speak spanish)
https://vntvbox.com/huong-dan-root-c...-dung-rockchip
hello please someone knows how to activate accessibility options in android 6.0 marshmallow in a tv box with rk3229 and SV6051P wifiChip.
I want to use the buttons remaper application to remap buttons on my remote control but in the accessibility services option it says "there are no accessibility services".
in another rom of android 5 if they appear but in the 6 no longer probe with several rom of android 6 and do not have the option
Originally posted by manu_manu4 View PostTry this app:
https://play.google.com/store/apps/d...edefiner&hl=en
Hello
Did someone perform this procedure on this firmware? try it but the leanback launcher stops everything else works fine
http://freaktab.com/forum/developmen...ox-pro-h96-pro
Originally posted by Sameer43 View Post
where can i find that? i can see the build number : rk322x_box-userdebug 6.0.1 MXC89L
Originally posted by LITO89 View Post
Carefully open your TV box and check if the Wi-Fi chip has written sv6051p take a picture of your badge, it can also be used later, also install the AIDA application so that it gives you information about your device
hi i use this rom in mxq pro 4k rk3229 and it works but it does not have root
This root does not work. I have tried a variety of ways to flash root.zip and SuperSu and they do not work even through TWRP. Have you actually rooted this Nougat image on this box?
Originally posted by PaulieP View Post
if some time ago I did it for TWRP ... But I did not like the ROM because the processes stopped sometimes ... and I decided to change to ROM:
LeelboxRK-8703 -7.1nv3 -Kodi-1225: (Available for the shell model is t95d MXQ PRO, MXQ MINI, Q2 pro, Q2 mini, Q1)
because this is more stable
for my smartbox MXQ PRO 4K RK 3229 (AV ORANGE)
I also found this video maybe you already visualized it
There are currently 1934 users online. 0 members and 1934 guests.
