rk3229 android 7.1 firmware(wifi 8703)
    Originally posted by tiagao_extremo View Post
    Nao funcionou, o aparelho fica travado na tela do Android. Tem outra sugestao?
    ainda nao
      Originally posted by raulmax3 View Post
      ainda nao
      deixa eu te falar acho que seu aparelho na verdade e 1gb e 8gb, porque as vezes as pessoas vende aparelho alterado tendeu
      • trebor
        trebor commented
        Editing a comment
        English please
      Sera? Porque antes eu usava ele com a rom de fabrica, usava bastante da memoria interna e mesmo com 2gb eu via o consumo de ram sendo usado. Com a rom de 1gb qualquer aplicativo ja deixa mais da metade da memoria utilizada. Eu ainda acho que exista alguma rom alternativa com as especificacoes originais.
      [ENGLISH VERSION] Could it be? Because before when i was using the stock rom there was plenty of internal storage available and even with 2gb ram i could check the ram being used. With the 1gb rom any application can fill more than half of the memory used. I still believe there's an alternative rom with the original specifications.
        Hello, I am from Brazil, and I thank you all for this firmware, it was the only one that worked on the mx9 pro
        I'm going to leave my fedd, the bot tv and 1G / 8G model mx4-V10 (android 4.4) and it worked perfectly in that box.
        just say it always occurred the IDB fail, but try one or two or three times on the computer that works.
        only the Led has turned red instead of blue, but works perfectly. If someone knows how to change tell me. thank you very much. follow the link below the right ro
        LeelboxRK-8703
        -7.1nv3 -Kodi-1225: (Dispon?vel para o modelo shell ? o t95d MXQ PRO, o MXQ MINI, o Q2 pro, o Q2 mini, o Q1)
        https://mega.nz/#!wrwyXYxD!0q0yVDFfT...FRiFYl_mUkVbTE
          https://mega.nz/#!SUYiiABZ!QsNTCLVr5...S1MKQfzBXDMqao android 6.0+ twrp+su
            Hello,
            I got an MXQ Pro 4K just this Jan 2019 from an online seller. By April it suddenly stop working. Stuck on Android screen. At first I thought it was an AMLogic machine and tried using diff versions of USB burning Tool but no go. USB BT wont detect the box using male to male USB cable. I tried recovery method as stated on paper that came with box but still, no go. I opened the MX box, and saw that it says RK329 on it. Also R329Q version 3.2 2018.08.14. I was able to search this page and tried to use Factory Tool v1.6 and the "mxqpro-6051-nv2*1114.img" firmware but again im back to FACTORY TOOL not detecting MXQ using USB cable. Do I need to short this board as stated on some pages? How do i go about shorting?
            Can I load the 1114.img to an SD card and try Android Recovery method using Apply update from SD card?
            Best way to unbrick this please. Thanks Freaktab!
              I just try Android 9, working fine on rk3229
                https://androidpc.es/firmware-android-9-hk1-mini/
                i tray it but not working in v88 black port .
                  Originally posted by q124250409 View Post
                  KingboxRK-8703-7.1nv3-Kodi-1225: (Kingbox K1, K1 plus, K2, but not for Kingbox K3!)
                  https://mega.nz/#!w2BXFbhQ!lpW2_C9W1...2M0FCzzNWf0o8I
                  LeelboxRK-8703-7.1nv3-Kodi-1225: (Available to shell model is t95d MXQ PRO, MXQ MINI, Q2 pro, Q2 mini, Q1)
                  Who can help me make a mod for R Box rk3229(wifi 8723bs)?.Thank you very much.
                  C?mo se pronuncia
                  hello you know that I installed this rom in my mxq 4k of 8 gigabytes of storage and 1 gigabyte of ram .. everything fine when installing shows me 3.2 gigabytes used of storage but every day the memory is filled alone being that I have not installed anything you know that I could be?
                    Hello All,
                    Can someone please share a link of this image as the link from the first post is invalid now?
                    Also is there any andriod tv os available for this box, please?
                    My box is:
                    T95D Android TV Box Rockchip RK3229
                    2G/8G
                    Wifi Chip - RTL8703BS
                    Printed on PCB Board:
                    T95N-RK3229_512X8
                    20170706_V1.8
                    Here is the high resolution picture
                    (inside the case)
                    https://ibb.co/XC43jWk
                    (front)
                    (back)
                    Many thanks
                    Hannah
                      Hello,
                      I found few relevant images here. Have not yet tried any though.
                        Hello All,
                        Anyway downloaded this ROM from here:
                        http://tvdestek.com/Konu-sineplus-8-...ware-wifi-8703
                        Rom - http://sineplus.tv/sineplus/LeelboxR...-kodi-1225.rar
                        Installed via Rockchip Batch Tool v1.8.
                        Everything is working including wifi and remote but Play Store is not working. It's always crashing. Any FIX available.
                        Regards
                        NB: Google Play Store is NOT working and crashing all the time. Any fix available please
                          Hello All,
                          My TV BOX: T95D Android TV Box Rockchip RK3229 Quad Core BT4.0 RAM 2GB DDR3 ROM 8GB 2.4GHz
                          Hi Everyone We have created this thread to collect all the NAND pin Short to Mask ROM Mode locations for all our members. Because firmware comes on android
                          This is the fully working ROM:
                          KingboxRK-8703-7.1nv3-kodi-1225.img
                          Download: https://mega.nz/#!w2BXFbhQ!lpW2_C9W1...2M0FCzzNWf0o8I
                          Android 7, Wifi, Playstore and Remote all working.
                            Firmware
                            Current line:
                            https://drive.google.com/file/d/1EPm...ew?usp=sharing
                              Originally posted by Gustav View Post
                              Firmware
                              Current line:
                              I tested it on v88mini II wifi RTL8723 and it has no wifi connectivity = (
