Hey, do you have a 6.1 version of the KingboxRK-8703[/B]-7.1nv3-Kodi-1225? It works on my device but I miss the rkremote and cetusplay doesn't work that well.
rk3229 android 7.1 firmware(wifi 8703)
Originally posted by Rccm1112 View PostThis rom is working great on a leelbox q1. Is there any way to change the wallpaper? Everytime I try to change it in another launcher I get an error. Also where is the remote.conf file for the remote located? I don’t see it in the system/etc folder.
Thanks in advance.
Rockchip devices use remote layouts in the resource.img(dts file), not like Amlogic that put files in /system/etc.
Updated Firmware (Different from above) I used for Rk329Q Mxq Pro 4k - For some reason it doesnt install using the other rockchip flashing software (for me) - I had to use Factory Tool v1.6 -
Otherwise it hangs on "android" logo screen....Tested & Workin on Rk329Q V-3.2 -Mxq Pro 4k : Android 7.1.2
Firmware (img File)
http://www.mediafire.com/file/q2ev24...9_USB.img/file
USE FACTORY TOOL INSTEAD OF OTHER SOFTWARE FOR SUCCESSFUL FLASH :
Factory Tool v1.6
http://www.mediafire.com/file/9irk7u..._v1.6.zip/fileLast edited by Gradez1974; 25 February 2019, 21:56.
Originally posted by Gradez1974 View PostUsing this on Mxq Pro 4k Rk322x, used it on 2gb Ram 16gb storage model seems ok so far - Think it should work for you - I just got the link of sum Russian site - Only thing I noticed the led light has reversed, blue light is power off and red light is power on...
https://mega.nz/#!HqQWiYRK!ewqppzjHB...nerWYXZdEhzFM8
Hi. I downloaded the LeelboxRK-8703 firmware from the first page. It's working fine but my device now it's only showing 1gb ram and 8gb internal storage. I'm downloading this file right now and i will flash my tv box with this one. Is this the better option or should i use the second file you posted? My tv box is a mxq 4k, rk3299, r329q v3.0, 16gb internal storage, 2gb ram. Thanks.
I bought mxqpro 4k r3229 box with 2G/16GB. It came with android 7.1 nougat was very slow. Replaced the firmware with KingboxRK-8703-7.1nv3-Kodi-1225:
It is working very nice. But the problem is youtube videos max resolution 720p and the RAM is showing 1 GB in settings. Also tried android 6 kingbox firmware on this box, but the network was not working. Please help to solve this youtube and ram issue or solve the issue of network on android 6 kingbox firmware.
Originally posted by Gradez1974 View PostUpdated Firmware (Different from above) I used for Rk329Q Mxq Pro 4k - For some reason it doesnt install using the other rockchip flashing software (for me) - I had to use Factory Tool v1.6 -
Firmware (img File)
Factory Tool v1.6
My box version is R329Q_V3.1. Is it suitable ?
YouTube will show 1080p option ?
Ram is 2G/16GB
Thank you
Originally posted by bibin View Post
Ram is 2G/16GB
Thank you
There are currently 2916 users online. 1 members and 2915 guests.
