This is a 7.1.2 ROM for RK3229 Tanix TX 2 that will flash with no problems to V88 and MX4N and MXQPro 4K - but it does not boot past the boot logo on V88.
Anyone able to fix this for V88 / MX4N, or make Android TV version? I don' t have any tools that work to compile Nougat images, onnly marshmallow.
I understand Russian. Only home button not work? Mouse and another work good? Now I try fix ir in topic starter images, but I can't pack system partition on windows, box not boot after repacking. And I can't write files in system/user/keylayouts
friend thank you from the past came a few days ago from a Rom and did not think it was finally this right I hope you continue with this willingness to help people God bless you.
I uploaded the leelbox rom for v88 already modified in mega.
If you want to remove status & navigation bars install framework-res.apk (in apk folder of my 7z file) in /system/framework
I put also SuperSu_v2.82.apk & X-plore_File_Manager_v3.98.14.apk to do that.
Becareful it's working on my old v88 but not with my other who have MX4VR board.
I you have already tested leeebox rom on your V88, it was OK.
downloaded img file does not want to open, "disk file is corrupted" file downloaded from multiple sources and still is still here the bug you know please advise me?
Hi, I create MOD of Kingbox img for MXQ 4K with WiFi 8189fs and esp8089 1/8Gb. http://4pda.ru/forum/index.php?showt...ost&p=71859146
May by someone saw Powerkey difinition in side settings menu (sleep, roweroff, reboot) for rk3229? I need fully poweroff device by shot press power button.
Reason: Add esp8089 support
Thanks for uploading - how would you compare Leelbox nougat rom to older ROMs? any faster or any different? Is it true 1080p and/or hardware acceleration?
I want to make ATV ROM out of it if so, but I do not have the tools to compile working properly signed Nougat rom
But it dont correct pack system partition for Nougat. For edit system you can mount system.img in linux (on virtual machine for example) by this command
sudo mount -t ext4 -o loop system.img system/
