The name "Nexus" does not indicate the porting from a Nexus device, but a rom as close as possible to the Google standards.
Real Android experience without chinese patches and bloatware. 100% compatible with apps in Google Play.
<DELETED>
SDK2
Multi-Windows
init.d
ethernet support
video jitter fix
PhabletUi and TabletUi from build.prop
all minix x7 hardware components working
Very fast and stable for videos and games
Reason: Administrative action
Strauzo! This intilal videotesting is amazing! For the first time Archos Video Player plays my hobbit 720p clip perfect with systembar hidden! (was autohide in this rom)
Also tested MX Player and it is also perfect in HW and SW, mabey small stutter in HW+ mode.
I have not tested anything else but but but but...this is something else so far.
Tested Netflix and video and this was same piqturequality as before but much smoother. But when trying another video my box frezze. And now i cant get in, think it is powersavemode or something like that.
Edit:Okej, call me stupied but i just needed to press remote button to wake it up.
Also i, after so much work I need to have a little fun.
The my minix x7 arrived only this morning.
Minix for me is the best manufacturer for build quality and hardware components.
My X7 is my first android mini pc.. (though I am not new to Android).. so far I've loved the build quality and beyond the first rev of firmware, it's been stable... works great with xmbc, which is all i really bought it for anyways.. also thinking about doing a custom kernel with gpu/cpu/ddr overclocking.. seeing if that works out..
Perhaps a stupid and lame question but you write that this is a ROM compiled with SDK2 and what does that mean in layman terms? I mean I know whats a SDK are but how does this differ from like finless 1.5a rom? Is this SDK the one from Rockchip or is it an hidden android sdk only for rom compiling.
Like I said, this is probably lame questions but if you don't ask you never knowm right?
sdk2 mean the new source code of rockchip. you can read about it searching in google.
That illuminates things for me, and it was as I suspected. I wonder why the box and sticks manufacturers still are using the old sdk1 since it obviously has flaws and bugs effecting performance of their devices. I guess the SDK from rockchip probablt cost a litte penny as well which might be the cause?
Thanks for the explaination and the links, they are greatly appreciated.
