all other file from nexus are the same
Minix X7 - ROM Nexus SDK2 and Multi-Windows
Guest
Guest
well only coping the file audio.primary.rk30board.so from stock 0004 rom to nexus i can do this:
From stafstorm post in minix forum:
"Maybe we should start with testing if pass through is possible at all with this ROM.
Download a DTS-wav test file here http://www.diatonis.com/surround_sound_music.html and see if you can get pass through when you play it with the following command in a terminal emulator.
alsa_aplay --device=hw:0,0 replace-with-path-and-name-of-downloaded-dts.wav"
I feel like a rustle but the command does not give me error, seems to work well
i don't have hardware to test hdmi pass through, what do you suggest as test. i don't understand nothing about this functionlity. BUt i can help in correction
Originally posted by strauzo View Postwell only coping the file audio.primary.rk30board.so from stock 0004 rom to nexus i can do this:
Guest
Originally posted by stafstrom View PostDo you have hardware that supports spdif pass through?
copy only the audio.primary.rk30board.so from stock to nexus and you can do your command.
i can open it also in xbmc latest gotham version and i I hear the same noise
in xbmc i can change audio from hdmi , analog and spdif
Originally posted by stafstrom View PostWithout hardware it's difficul to test.
But I just reallized one thing, I forgot to mention that you need super user rights before you run alsa_aplay.
Dan if you could test it again but use the command su first this time?Originally posted by strauzo View Postbe sure to restore all original audio files of the nexus, and copy only
/system/lib/hw/audio.primary.rk30board.so from stock 0004 rom to nexus rom
after you can try the command alsa_asplay
1|u0_a102@android:/ $ su alsa_aplay --device=hw:0,0 /mnt/sdcard/test.wav
sh: sh: --: unknown option
so ran it without the dashs before device and got this:
1|u0_a102@android:/ $ su alsa_aplay device=hw:0,0 /mnt/sdcard/test.wav
sh: /mnt/sdcard/test.wav: can't execute: Permission denied
Originally posted by strauzo View PostTo switch audio use the free app from google play SoundAbout
if you like the old tabletui you can set this in build.prop (status bar at the bottom)
for HDMI passthrough you must swap only two lib (in other thread you can find this libs)
many new tv scale automatically the rom you don't need hdmi zoom, (es. for Samsung TV the button P-size on remote control) but if your tv not scale well with menu options, you can use this command:
echo 95 > /sys/class/graphics/fb0/scale
(thanks sam321 for this)
i suggest to change the number 95 from 90 to 100 to find your best fit. when you have your number you can add a script in init.d folder to do the scale automatically at boot time
the rom work already in landscape mode and start in landscape mode. If you have problems because you have started an app the force the display in portrait, use the already installed app rotation lock, set in landscape mode and after on top right status bar click on rotation lock 2 time. the final position of the icon inside the top right status bar must be rotation locked.
All can help me to add other options to this very very good base pure android rom.
Sory for the newbe question. But I have been trying to write the script for the scale to be changed to 94 and can not seem to get it to work. It works ok if I do it on a terminal window but not on a script that I then put in the init.d folder. Can you give me an example of what is supposed to go on the script file for the scale to change at startup.
thanks
rdavidowski
Originally posted by danfozzy View Postreflashed the nexus system.img then transfered only the audio.primary.rk3board.so and stafstroms 004 libmedia.so, rebooted then ran the command. this is what it spat out:
$ su
$ alsa_aplay --device=hw:0,0 /mnt/sdcard/test.wav
Originally posted by stafstrom View PostYou must run su before alsa_aplay, not on the same row, like this
$ su
1|root@android:/ # alsa_aplay --device=hw:0,0 /mnt/sdcard/test.wav
aplay: main:655: audio open error: Device or resource busy
There are currently 2551 users online. 2 members and 2549 guests.
