Minix X7 - ROM Nexus SDK2 and Multi-Windows
Originally posted by Casanoaa View PostAny jiddering and choppiness when hearing music or streaming video?
Xbmc or Tunein radio.
Sv: Minix X7 - ROM Nexus SDK2 and Multi-Windows
Originally posted by danfozzy View PostI haven't had any skipping or juddering in streaming music from spotify or my nas, no juddering in my 720p movies and tv shows using xbmc, and none of them artifacts either.
Originally posted by danfozzy View PostIs there anything we can add to the build.prop to keep it permanently in landscape mode?
Also how to we change it to tablet mode? Having the tablet bar at the bottom instead of the 3 buttons. missing the auto hide bar option
#2: Set 'ro.rk.systembar.tabletUI=true' in build.prop. With this setting you will lose the multi window buttons, though (or at least the T428 ROM works that way).Last edited by Molle; 08-29-2013, 21:23.
Originally posted by Trhuster View PostStrauzo! This intilal videotesting is amazing! For the first time Archos Video Player plays my hobbit 720p clip perfect with systembar hidden! (was autohide in this rom)
Also tested MX Player and it is also perfect in HW and SW, mabey small stutter in HW+ mode.
I have not tested anything else but but but but...this is something else so far.
Strauzo, THX ALOT!
Great rom
Thanks for putting this rom together!
For those who are interested, I have attached various screenshots.- The resolution is 1280x720
- This AnTuTu bencmark score is 18029.
- The device reports itself as Nexus 7 (for app compatibility)
One app I have found to report an error - Blinkbox (UK app). It complains that the Google DRM libraries are not installed and so refuses to play any content.
Will be sticking with this rom
I have a question for the developer - can the benefits of this rom be combined with the latest kernel from Finless 15a (ie. with 1080p support)?
Originally posted by strauzo View PostXBMC + Nexus is very good.
720p very well from local network, internet and storages.
for 1080p videos you need the xml file advancedsettings.xml to enable hardware decode also on some 1080p videos.
i suggest to use the xbmc libstagefright version: http://forum.xbmc.org/showthread.php?tid=152005
but i tested also the standard nightly build. that work well.
I must say I find it strange that a entirely system has to be flashed in order to change the output.
I have set my output in android to 1080px60 and I supose that now the android just upscales the image instead of true 1080p.
One thing also is the lower bar which doesn't dissapear when starting xbmc.. there should be some kind of autohide feature - the bar is hidden when running the stock video player.
Originally posted by Maximilian View PostOne thing also is the lower bar which doesn't dissapear when starting xbmc.. there should be some kind of autohide feature - the bar is hidden when running the stock video player.
There are currently 2461 users online. 3 members and 2458 guests.
