Minix X7 - ROM Nexus SDK2 and Multi-Windows
yeh changed the 2 files, including the 004 libmedia, thats what ive done from the start of this testing. what i think is tripping us up is that there is no option for passthrough in soundabout. in the minix rom or the finless rom, the passthrough wouldnt work unless passthrough was selected in the audio settings within android and also in xbmc
Originally posted by danfozzy View Postyeh changed the 2 files, including the 004 libmedia, thats what ive done from the start of this testing. what i think is tripping us up is that there is no option for passthrough in soundabout. in the minix rom or the finless rom, the passthrough wouldnt work unless passthrough was selected in the audio settings within android and also in xbmc
Why I don't believe this is because the neo X5 doesn't even have the possibility to select hdmi pass through in audio settings, still pass though is possible with the libmedia hack in xbmc.
I have also tested to not select spdif pass through on my neo X5 but pass through still works in xbmc.
I's a really tricky problem this, but I have check which lib's libmedia depends on and got the following result.
libui.so
liblog.so
libcutils.so
libutils.so
libbinder.so
libsonivox.so
libicuuc.so
libexpat.so
libcamera_client.so
libstagefright_foundation.so
libgui.so
libdl.so
libaudioutils.so
libmedia_native.so
libc.so
libstdc++.so
libm.so
libaudioutils.so looks interesting, might be a good idea to try replace that one.
Originally posted by stafstrom View PostI'm a bit confused here, I don't think the libmedia hack should be affected by what's selected in the audio settings, but I could be wrong.
libui.so
liblog.so
libcutils.so
libutils.so
libbinder.so
libsonivox.so
libicuuc.so
libexpat.so
libcamera_client.so
libgui.so
libdl.so
libaudioutils.so
libmedia_native.so
libc.so
libstdc++.so
libm.so
Guest
Originally posted by danfozzy View Posti will replace these files one by one, but with the libmedia patch on x7 it will only work if the passthrough setting is selected in the android options. ive tried it several times when first trying it out on the minix roms
like the hdmi zoom. that with this command work echo 95 > /sys/class/graphics/fb0/scale
for example to see what happen when you change audio autput in settings, start logcat and read what happen.
but the problem now is different. the hdmi pass-trought work, we must only investigate why the audio is not good.
stafstorm you can't test with your hardware ?
Originally posted by strauzo View Postthe switch in settings is not a problem. generally this type of switch can be done also with script command in terminal emulator. or with a configuration file.
ive just taken a logcat,
i first played a dolby digital movie and then a dts movie on the standard audio setting, RK29_RT5616. gave static noise.
i came out of xbmc, change the android audio setting to RK29_RT5616 PASSTHROUGH (this setting only has passthrough for aac as set by minix, stafstroms patch seems to override this)
loaded up xbmc played the dts movie, and i have dts surround sound playing perfect.Attached FilesLast edited by danfozzy; 09-01-2013, 22:00.
That might be the reason why pass through still works for me, even when I have not selected pass through in audio settings.
If you check the /system/etc/audio_policy.conf file, what does it say, is the flag AUDIO_OUTPUT_FLAG_DIRECT
there?
See this page: http://source.android.com/devices/audio.html
Originally posted by stafstrom View PostI have been thinking a lot on this, then I remembered I have made changes in my /system/etc/audio_policy.conf
there?
See this page: http://source.android.com/devices/audio.htmlAttached FilesLast edited by danfozzy; 09-02-2013, 10:41.
Guest
If i remember well the only one differences in audio_policy.com from stock and nexus, is the path of the file .asoundrc that danfozzy don't find in the stock rom.
this file should contain an important part.
another way to debug the problem, and find what files are involved is this:
get the first stock rockchip rom 1.8.2013 and the last 0004 and compare with a tool like winmerge what file are changed.
you need the two system.img and you can mount it on windows like normal disks with the tool linked above in previous posts. OSFMount
to unpack the update.img to have the system.img you can use the wendal tool. rename the update.img file in wendal.img copy it in the wendal tool folder and run the bat file Runme.bat. select 1 to extract and the result system.img is copyed in the temp folder.
After you can mount this system.img with the tool OSFMount
Originally posted by strauzo View PostIf i remember well the only one differences in audio_policy.com from stock and nexus, is the path of the file .asoundrc that danfozzy don't find in the stock rom.
Originally posted by danfozzy View Postuploaded the files from both roms, main differences is the lack of the audio output flag direct and references to passthrough in the nexus config
But I don't think if it's possible to set the AUDIO_OUTPUT_FLAG_DIRECT on the primary output.
You need hdmi or spdif output, and to configure that you probably need a .asoundrc file like strauzo says.
It's strange you can't find that file in fw004, you know that a file with a dot (.) before the name is hidden, because I'm pretty sure I have seen it on my X5.
im aware that it is a hidden file..
ive just done a full search on a fresh install of the 004 rom. its not on my system at all
in terminaal when i cd ~/ it takes me to (as that is supposedly it is in this rom)
/data/data/jackpal.androidterm/app_HOME
but when i list the dir its emptyLast edited by danfozzy; 09-02-2013, 13:57.
Guest
Originally posted by rdavidowski View PostHello Strauzo
Can anybody point me on how to hide the navigation bar at the botton permanently.
rdavidowski
restart your device
and install from google play full!screen app https://play.google.com/store/apps/d...orn.FullScreen
There are currently 2169 users online. 3 members and 2166 guests.
