MK808B_digitopMod_MINIX_NEO-G4_port (0730) _Sep2013
    Anyone tried the new XBMC optimised for Rockchip MiniX hardware on this rom?
    http://www.freaktab.com/showthread.p...-1-8-ROM/page6
    I was just about to ask you if I install this rom on mk808b if it will work
    I guess I'll try then
      Yes it works
      Change build.prop to ro.product.model=GT-I9300 and ro.product.manufacturer=Samsung
      Also install the latest version that will work on this rom with above changes
        Yes it works
        Change build.prop to ro.product.model=GT-I9300 and Ethernet connectionoduct.manufacturer=Samsung
        http://flumpster.lolcakes.com/androi...ETA2_Test1.apk
        Thanks, will try that
        On another note what drives me crazy that after reboot I have to disable and enable ethernet to get it working, any fix on that? Thanks!
          Follow these steps
          1) Install app from Google Play - SManager
          2) Create a new file with the extension "sh"
          3) Edit the file as follows:
          ifconfig eth0 down
          ifconfig eth0 up
          4) Run SManger, and configure it to run at system startup the script that you created in step 3.
          Make sure that the script is run with root permissions, and most likely that you have installed Busybox.
            Follow these steps
            ifconfig eth0 down
            ifconfig eth0 up
            Thanks!
            I use the solution with my mx1, I do the same on this stick then
              New MK808B_digitopMod_v3.5.5 XBMC Edition (24 Dec 2013)
              Features
              1. Overclocked GPU to 400 mhz(default 266 mhz)
              2. Includes working XBMC Minix Edition Beta 2
              * It has been optimized for the Rockchip VPU, so you'll get better video performances than on a generic
              XBMC.
              * VC1 and VP8 accelerated.
              * It contains the passthrough hack
              * It has a distinctive android signature, so you can install it alongside any other XBMC. With further
              updates, you won't loose your settings.
              * It is based on Frodo (12.x)
              * Working MPEG2 acceleration
              * New GFX
              * Handle issue with bottom ghost pixels on some vids
              * External players support
              * Do not handle POWER button in XBMC (solves issue when using the remote power button)
              * Remove HDMI audio option (prevent passthrough issues)
              3. Includes many updated apps like
              Build Prop editor
              Lidroid File Explorer
              Es File Manager 3.0.8.0
              Cifsmanager (mounts samba shares for XBMC)
              Mount Manager(to auto mount shares)
              Dolphin Browser 10.2.1
              NofrillsCPU (to overclock device)
              Tuneinradio v11.1
              Videomix v1.7.8(to watch movies)
              MxPlayer v1.7.21(to play movies, remember to enable H/W+ mode for better playback)
              Youtube v5.3.28
              Pimpmyrom &
              Updated Google apps
              Post Installation
              Remember to change animations to 0.5s in developer settings and enable GPU for 2D rendering
              Also run Pimpmyrom for some extra usefull network & speed tweaks.
              There is also an enable/disable Vsync setting in Pimpmyrom, but don't know if it works.
              http://www.mediafire.com/download/02ee2d8m1g002on/MK808B_digitopMod_v3.5.5%20XBMC%20Edition.zip
              For MK808 devices
              Just replace the kernel in the zip file with an overclocked MK808 3.0.8 kernel from here - http://www.multiupload.nl/L2LWQ0N3GC
              Remember to rename the kernel to kernel.img before replacing it in the rom's zip file.
                Features
                XBMC.
                * New GFX
                Very nice! Thank you
                Any chance you will do something similar for mx1 ?
                  Is there any Android 4.1 or CWM roms for mx1 and which it the newest, best at the moment?
                  I read Rikomagic MK802IIIS roms also work on mx1.
                  If there is a decent rom for mx1, I can try to update it like this rom, don't want to update an old rom that no one is going to use.
                    That would be awesome! Yes that rom is working great
                    One problem is that I can't figure out how to install cwm with this rom.
                    Leolas offered to create custom version tho
                    Here is link to download the rom http://www.sendspace.com/pro/dl/sxms6w
                      Features
                      XBMC.
                      * New GFX
                      Build Prop editor
                      Tuneinradio v11.1
                      Youtube v5.3.28
                      Pimpmyrom &
                      Updated Google apps
                      Post Installation
                      For MK808 devices
                      Nice work.
                      One question.
                      Can i use this rom with minix x5 mini ?????
                        Originally posted by pajopasa View Post
                        Nice work.
                        One question.
                        Can i use this rom with mini x5 mini ?????
                        Yes, it works on MiniX Neo X5 but not sure about X5 Mini? It should work as it has the same hardware.
                        Just change the kernel in the zip file with a MiniX X5 Mini Android 4.1, 3.0.8 one.
                        If you don't have one, you can use this tool to extract it from a stock rom. It will be copied to the temp folder of the app.
                        RK3xxx_firmware_tools v4.1.17
                        http://pmislot.spaces.ru/files/?LI=5...&read=44607655
                          Yes
                          Just change the kernel in the zip file with a MiniX Android 4.1, 3.0.8 one.
                          Ok.
                          Tell me something mo123
                          I have one mk808 and if i wont to put this kernel_cpu1512_gpu533_ddr533 did i have to change the boot.img or i can use the one included in this new rom?
                            Ok.
                            Try the MK808, Android 4.1 720p, kernel_cpu1416_gpu400_ddrstock
                            Iif you go higher for the CPU you need extra cooling or a heatsink. Anything for CPU from stock to 1512 should work. Also the max the GPU can run is 400 mhz, it's a limitation on dual core TV Sticks at the moment, the 533 mhz GPU will actually make your device run slower. Even editing boot.img won't work, it was confirmed by the developer of the overclock tool for kernels.
                            You can use nofrillscpu(included) or setcpu to lower the CPU speed if needed.
                            If you do use an overclocked kernel eg 1512 cpu, 400 gpu and 533 ddr make sure you have a heatsink and extra cooling otherwise your device will overheat and break.
                            The kernel that is included is only for MK808B and is 1416 cpu, 400 gpu & stock ddr.
                              But do i have to change the boot.img also or a i can only change the kernel.img to have the new settings???
                                Only change kernel.img for MK808. Make sure it's Android 4.1, 3.0.8 kernel.
                                MiniX Neo X5 Mini kernel might not work since it's Android 4.2, 3.0.36 kernel and not Android 4.1.
                                The overclocked kernel I made for MiniX Neo X5 Mini might only work on the stock Mini's firmware, just flash with RKAndroidTools v1.37 and only select kernel and flash not IDB erase.
