MK808B_digitopMod_MINIX_NEO-G4_port (0730) _Sep2013
Originally posted by 1234klaus View Postas reported earlier, this om is having some issues with the keyboard, with the ENTERkey not usable in the address bar of the stock rowser. now I am happy share a way I found to solve this. Since I often need Japanese input, I just installed the GOOGLE JAPANESE INPUT App. Now I can finally use my keyboard accodring to its lables, but furthermore, this also SOLVE the issue with the enter key for me. So if you want to try it out, maybe you find some other custome keyboard to enable the enter key in the browser's address bar again. Good luck!
I tried several input/keyboard apps but with no luck
Someone else got suggestions to fix the ENTERkey for the address bar of the stock browser
R: MK808B_digitopMod_MINIX_NEO-G4_port (0730) _Sep2013
Hy guys,
I just see on allminipc forum that is an 2dark4u overclock extreme kernel for ug802.
I wonder if this kernel will work on a modded mk808(heatsink and fans)...offcourse whitout wifi(i have an usb ethernet adapter).
The kernel is:
"kernel_720_GPU500_CPU1704_RAM1320"
If someone tested this kind of kernel already...
Inviato dal mio GT-I9000 con Tapatalk 2
The kernel is:
Why do you need it so high anyway? The 2dark4u mk808 kernel v1.4 is pretty much the best we can get. The bottleneck has always been the poor GPU, making the quad cores on the market almost useless as they have the exact same one.
Originally posted by vickpayne View PostHonestly, i never understood why do i have to change the kernel on my 808 if everything is working fine.
If you're talking about this rom, it's because the mk808b has a different wifi chipset to the mk808. It will still work, but you will lose wifi.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
RKRemoteControl Touch & Mouse mode cause MK808B to reboot
Hi all,
I am experiencing problems running RKRemoteControl with this ROM, when using Touch and/or Mouse mode, the MK808B will force into reboot, in Control mode, the buttons works ok.
Anyone sucessfully running RKRemoteControl with this ROM? Thanks!
Re: MK808B_digitopMod_MINIX_NEO-G4_port (0730) _Sep2013
The kernel is:
I guess the worst that can happen is that it gets unstable, so you can just try it if you want.
Sent from my GT-I9100 using Tapatalk
Anyone sucessfully running RKRemoteControl with this ROM? Thanks!Currently Using:
Retired Devices:
Originally posted by ididmytime View PostYou need the newer version of RKRemoteControl on this rom. Using the older version causes rebooting.
Location: Vendor_1915_Product_af11.kl at /system/usr/keylayout/ and
Vendor_1915_Product_af11.kcm at /system/usr/keychars
Replace Vender_1915 with the name of your keyboard by getting the name from step 2.
2) Use this guide to remap your keys - http://droid-den.com/android-guides/...ware-keyboard/
3)Also try to use a different browser like firefox, opera or dolphin.
There are currently 5747 users online. 1 members and 5746 guests.
