Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
To anyone interested I got this box running great by using a root explorer/cleaner called sd maid which allowed me to remove glichy Alice ux. I installed top launcher 2 then remove alice. Also lets you remove all the garbage factory bloatware apps and now I actually like this box. Nova launcher and a few others don't run right on this box just to save you time on having to reburn your box.
Originally posted by jillblow777 View PostTo anyone interested I got this box running great by using a root explorer/cleaner called sd maid which allowed me to remove glichy Alice ux. I installed top launcher 2 then remove alice. Also lets you remove all the garbage factory bloatware apps and now I actually like this box. Nova launcher and a few others don't run right on this box just to save you time on having to reburn your box.
Originally posted by neutronzzz View Post
i wont buy any tanix box anymore, aliceUX so laggy. and no root on my TX6 android 9.0
Originally posted by c,lei View Post
Tanix TX6's are rooted by default. It's why "rooting apps" shouldn't be used with them. Do yourself a favor, learn something about the stuff you claim you own.
mine is not rooted, i have flashing my box, but wifi cannot turned on. where i can find correct firmware for my TX6 4/32?
I have no idea, since it sounds like you bought one of the TX6 knockoffs,and screwed it up by by flashing it with firmware that wasn't meant for it's hardware (No Wifi). Contact the people you bought it from.
Originally posted by Hikvision View PostLatest TX6 firmware - tx6-9.0-20190615 (for 2*16)
Attention !!!
There is no certification сервисов GOOGLE in the firmware - no login google
You can register yourself, there is a method
But in Aida64 now writes ALLWINNER )))
https://drive.google.com/drive/folde...9-n1XbhiKl3pmr
H6_9.0_4Gddr_8822bs_20190114.img
Tanix_H6_4Gddr_8822bs_20190228.img
Tanix_H6_4Gddr_8822bs_20190323.img
Tanix_H6_4Gddr_20190507.img
TX6_H6_9_4Gddr_20190506.img
TX6_release_H6_7.0_20181219.img
There are currently 3196 users online. 0 members and 3196 guests.
