Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Guest
Originally posted by ahmed70 View PostI do not have this window in my tv box I try to find it but I failed maybe the version
my version ls
android security patch level: February 5, 2019
Kernel version: 4.9.118
1 thu abril 18, 2019
Originally posted by RiCkLaR_atvX View Post
If you are on an old Firmware, then of course you must update, use the 2019.07.22 firmware. It is the last released official firmware for Tanix TX6 devices that I know of and is what is currently in my Tanix device. The firmware is not perfect, but Tanix did fix a lot of the major problems that were in the other Pie firmware releases.
1- From where I can download this update
2- When I update the device, will I install the software again or does this update keep the programs installed on the device
Originally posted by ahmed70 View Post1- From where I can download this update
2- When I update the device, will I install the software again or does this update keep the programs installed on the device- the update is an .IMG file that needs to used with additional software like SDbootcard maker or the PhoenixUSB Tool for installation. If you keep reading back inside this same forum topic you will find the firmware and installion instructions.
- the Update will erase all your data! You can use the app Migrate from Play Store to at least make a zip file of all your apks to be able to extract and then install quickly in new rom, Migrate app makes Zips to Flash in TWRP for phone ROMs, but no TWRP in factory ROMs, but no worry you will instead use file manager inside Android to install apks manually after unzipping the Migrate-Backup.zip -- will need a separate SDcard or USB drive to hold and transfer the backup.zip to new ROM installation.
Originally posted by RiCkLaR_atvX View Post- the update is an .IMG file that needs to used with additional software like SDbootcard maker or the PhoenixUSB Tool for installation. If you keep reading back inside this same forum topic you will find the firmware and installion instructions.
I found in the setting, app, choose the program unmark show notifications and it worked for me
thank you very match again
Originally posted by c,lei View PostCouldn't find the Migrate app on Playstore. If we are talking about the same app, this may the reason why:
I forgot it got removed from the official Play store, but you can still download it for XDA or Android File Host website or its Telegram group.
Originally posted by Tzr808 View PostHi all, someone use a wireless game controller with this tv box?
I already have a cable one but it only works with some games...
Thank you in advande!
Playstation 2 controllers both wireless and cabled using the Playstation 2 TO USB adapters found on **** work fine. Just plug the Playstation 2 controller into the adapter. Not sure about the Playstation 3 controllers, they seem to work as usb cable joysticks but don't seem to have wireless/bluetooth support under android.
before read your suggestion i buyed this one:
8Bitdo Gamepad Wireless Bluetooth SF30 PRO
and i will try it.
anyway i would prefered a wireless one because the connection of tv box to internet is by wireless and i have fear about a conflict between bt and wireless.
Edit: today i tested it... it work in some games but in roblox no way to use... maybe the problem is roblox because this is the same thing that happened with cabled controller that i used before... tomorrow i will try another one!i hope it will work well!
What Bluetooth issue? Mine works fine with Android 9.
If you buy the cheapest model 2GB Ram of TX6 it is possible it will come with a 2.4Ghz WiFi only module and no Bluetooth.
thank you!
and i will try it.
There are currently 1898 users online. 0 members and 1898 guests.
