Any idea where the problem can be.
Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by tonygts View Post
Would appreciate your further advice on Installing Armbian .
1. Where can I get the Armbian images?
2. Can Windows PhoenixCard app be used to burn on SDvard or USB pendrive? If not which Windows app can then be used?
3. What cautious steps shoud I look out when installing Armbian?
Thanks in advance.
Also can find Armbian development builds made for TX6 by balbes150 here on freaktab (balbes150 is also on Armbian forum) : https://forum.freaktab.com/forum/tv-...177#post813177
Armbian can use the Balena Etcher program to make the bootable SDcards, Etcher has a Windows version downloadable from there official page.
Originally posted by tonygts View PostI tried uploading the TX6version.png (.png extension, 290KB) which is in this link: https://drive.google.com/file/d/1dnL...w?usp=drivesdk , and I still got "Error Uploading Image" as shown in the screen shot here : https://drive.google.com/file/d/1h03hesvkFnMuwolTxzzfPXWLLuW5r6Wd/view?usp=drivesdk
Thanks. I'm testing now with:
postimages: https://postimg.cc/7G11Y6wq
imgbb: https://ibb.co/NNj490t
Working!
Thanks againLast edited by tonygts; 21 September 2020, 11:04.
Originally posted by RiCkLaR_atvX View PostYou REFORMATTED the Image? Not just change the extension?Last edited by tonygts; 21 September 2020, 12:34.
Visit the Ambian website and forum for more info.
RiCkLaR_atvX
Hi RiCkLaR_atvX
As you can see from this screenshot https://drive.google.com/file/d/1dnL...w?usp=drivesdk that my kernel version is 2020.0515, but the latest version posted in this thread as well as that in https://androidpctv.com/?s=tx6
, is 2019.0722, almost one year old.
1. Why is that there isn't any more update since 2019.0722?
2. My current version 2020.0515 could be an OTA version perhaps, but where can I find the last flash image version from which the chain of OTAs are updated up to 2020.0515?
Originally posted by Brent Norton View Post....
I found the answer to my original question over at https://4pda.ru/forum/index.php?showtopic=929205
And this method does not touch any of the devices internal storage, so I can test out the various builds for the TX6 / Allwinner H6 without the risk of bricking the device or wiping the current configuration.
Cheers
Since your are able to boot tx6 firmware on SDcard, can you access the internal memory root directory to copy and paste file?
Btw, which version of TX6 firmware that you have successfully installed on SDcard and booted from there?
Have you tried installing it on USB pendrive and boot from the drive?
Thank in advance for sharing your experience..
I have connected a capacitive touch screen to my Tanix TX6 but it works as single point touch device only. I have test the monitor on other Android devices and it works fine, so the TX6 has probably problem to recognize it.
I have read that some TV Boxes have not built in the hid-multitouch.ko module, so I found an hid-multitouch.ko file and used the app Android Module Loader to load it to the TV Box but even after that the problem remains the same.
My TX6 rom build No is 20190722
Do you have any idea how I could resolve that problem?
Example:
Code:android.hardware.touchscreen.multitouch.distinct.xml android.hardware.touchscreen.multitouch.jazzhand.xml android.hardware.touchscreen.multitouch.xml
Might also need the "Permission File" located in /vendor/etc/permissions/
Example:
Originally posted by RiCkLaR_atvX View PostThe new TX6S has worst heating problem than the old TX6, even with a fan On the New Chip it will go into thermal Redzone. The new chip has just as many bugs in Android 10 OS as the Android 9 OS on the old TX6. So if you are going to update newer TVbox, abandon Allwinner CPU boxes and get Amlogic S922X or S905X3.
Yes, you should be able to access the eMMC as a secondary drive in Linux and that cmd should work, don't forget to set file permissions, and maybe possibly running over ADB this cmd$ ./system/bin/su install
Worth a shot. And YES Armbian can be installed and ran from an SDcard for the TX6, never tried editing the eMMC form Armbian myself but good luck!
Regards
Sent from my SM-G935F using Tapatalk
Originally posted by Bertonumber1 View PostHey RiCkLaR_atvX so my box aeromedia Nanomax is a h6, after installing aida64 and checking it out the thermals were shocking, red zone all the way . I melted a hole in the bottom directly above the soc, installed this Pi fan for cooling and it's dropped it down to 32 degrees which is icy cold in comparison.
What is it with these devices?
Originally posted by RiCkLaR_atvX View PostShare a picture of the box with RaspberryPi fan? I just have a huge 80mm computer usb fan on top of my H6 box and stays under 75*C even under heavy load.
Well too much things to list, lol, but I still like the TX6-H6. One thing to note is the kernel really should be upgraded to mainline linux upstream, which supports the CPU extensively, but the current Android kernel currently in these boxes is a mess with proprietary blob hacks to get it to function semi-stable, and the kernel doesn't handle all chip properties correctly like correct usage of ram, etc., etc.
There are currently 1811 users online. 0 members and 1811 guests.
