Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
Originally posted by neutronzzz View Post
download firmware from this post:
then burn it with phoenix card, u can found it here:
after success burn the FW, trun off ur TX6, insert the card then turn it on again. it will start flashing ur TX6. its work on my TX6
Originally posted by sangramd21 View Post
Phoenix card didn't work at box was completely dead. Was not powering on as well. Finally installed firmware using phoenix suite & usb to usb cable. Working fine now. Cheers.
Originally posted by Kotalke View Post
@sangramd21 which one firmware have you installed finally?
Originally posted by neutronzzz View Postreal tanix TX6 has no problem when playing 4k video, smooth and no lag
have u try this firmware?
https://chinagadgetsreviews.com/down...ro-tv-box.html
Ok, so I decided to downgrade my 20190730 firmware to 20190722. Now 5.1 surround audio works... but only in the Kodi stock app (ver. 18.1). All others aplications don't work with 5.1 audio while watching any video (the screen runs smoothly, but with NO sound). I've tried with tons of options, settings, configurations, but nothing helped.
Any suggestions what else I could do or what firmware will support 5.1 sound?
I know that Kodi has its own built in player and codecs.
I've tried the following firmwares:
20190228 - no WIFI at all, video with 5.1 doesn't start at all.
20190615 - WIFI only with 2.4 GHz, no 5.0 GHz, video with 5.1 starts, but no sound.
20190722 (current installed) - both frequencies work, video with 5.1 works, but only in Kodi (ver. 18.1).
20190730 (version which came from the shop) - both frequencies work, video with 5.1 doesn't work at all (maybe because the Kodi was ver. 18.4).
I have TANIX TX6 4/32GB (WiFi dual Band and Android 9).Last edited by Kotalke; 18 December 2019, 14:54.
Originally posted by zchmoken View Post
It should. I bought a Pendoo box & flashed Tanix fw on it no problem.
I just started to wonder if the official Android TV Boxes have the same problem or not.
Guest
Would it be possible to port Android10 from Tanix TX6S model?
Or, if I find .img file for it, could I just flash it and expect everything to work?
The only difference I see is H616 SoC, maybe the rest of the hardware is the same?
Guest
Originally posted by Kotalke View PostNot without some modifications I think. TX6S model has a different hardware than TX6, so it means also different drivers.
There are currently 2870 users online. 0 members and 2870 guests.
