Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
My TX6 box is dead & not showing any light. It was not booting up after I tried installing Magisk on it. I tried factory reset I but no luck. So I t tried to flash the firmware again but as the firmware installation was stuck in between, I powered off the device. Now the device won't power on at all. Its dead. Could you please help to restore the device? Not even a month I purchased it :-(
Originally posted by sangramd21 View PostMy TX6 box is dead & not showing any light. It was not booting up after I tried installing Magisk on it. I tried factory reset I but no luck. So I t tried to flash the firmware again but as the firmware installation was stuck in between, I powered off the device. Now the device won't power on at all. Its dead. Could you please help to restore the device? Not even a month I purchased it :-(
Originally posted by Hikvision View Post
after success burn the FW, trun off ur TX6, insert the card then turn it on again. it will start flashing ur TX6. its work on my TX6
i installed again the rom, may version, using cable linked to pc and the tanix reborn!
it work perfectluy till today!
try the flash again...
no more magisk for me before i am sure about it!
Hi, I have a TX6 clone. I have a problem with slowing down when I click on the icon.As far as I understand the problem is with the Hardware Layers, it is not working properly. I have tried almost all the firmware from this site and it always happens. Is there anything I can do about this.If anyone knows what to do, hI would appreciate it.
Originally posted by metlahead View PostHi, I have a TX6 clone. I have a problem with slowing down when I click on the icon.As far as I understand the problem is with the Hardware Layers, it is not working properly. I have tried almost all the firmware from this site and it always happens. Is there anything I can do about this.If anyone knows what to do, hI would appreciate it.
i have tx6 clone (pendoo x6 pro) and it runs like a hunk of crap with the stock pendoo firmware that came on it.. got an updated firmware, it's a bit better but video playback is still pretty choppy tried all dif decoders and players. tried Tanix_TX6-SCV1 firmware and it's about the same performance wise as the new pendoo firmware.. ugh these things are crap! are the real TX6 boxes this bad too? 60fps videos look to be about 25fps or less it's so brutal.. wondering if anyone else has these pendoos (or any other clones) and had any luck with the tx6 firmwares??
Originally posted by pcdude28259 View Posti have tx6 clone (pendoo x6 pro) and it runs like a hunk of crap with the stock pendoo firmware that came on it.. got an updated firmware, it's a bit better but video playback is still pretty choppy tried all dif decoders and players. tried Tanix_TX6-SCV1 firmware and it's about the same performance wise as the new pendoo firmware.. ugh these things are crap! are the real TX6 boxes this bad too? 60fps videos look to be about 25fps or less it's so brutal.. wondering if anyone else has these pendoos (or any other clones) and had any luck with the tx6 firmwares??
have u try this firmware?
There are currently 1506 users online. 1 members and 1505 guests.
