Tanix TX6 TV Box - Allwinner H6 4/32GB Dual WiFi BT4.1 or 5
I have a TX6 4/32GB so far it has worked well, now i am showing "TX6" on TV and the display shows "boot", TX6 does not load, it has stopped. I can only run TX6 with SD card on which I have IMG_20201225_093503.img.
The question is, how do I load IMG_20201225_093503.img to TX6, that TX6 work without SD card, because the operation TX6 with SD card is very slow?
Im asking for help.
thanks for the answers.
FrankLast edited by Frankk; 31 December 2020, 12:21.
Im asking for help.
Frank
https://chinagadgetsreviews.com/down...rd-v4-2-4.html
Please post it, IMG_20201225_093503.img
I want to try it )
Originally posted by Frankk View PostThanks for the help and advice.
I tried and it doesn't work.
However, it works if I select "Startup" in "Write mode" in PhoenixCard, in which case the system works from the SD card and everything is very, very slow.
Best regards
Frank
I want to try it )
https://4pda.ru/forum/index.php?show...#entry82248937
Thanks for the reply.
I've tried this before. It does not work as a "Product" as described in this article. It works, however, if I check “Startup” then the system boots from the SD card and everything is very slow.
Anyone knows what is the manufacturer of TX6-H Allwinner H6 4GB/64GB with RTL8822CS wifi/bt ? This is supposed to be a newer version. After failing to completely unroot this device, I flashed with original Tanix firmware 20190228 img but know wifi and bluetooth are dead. Possibly and some other features?
I cannot find a TX6 firmware that contains driver 88x2cs.ko in /Vendor/Modules and Tanix won't help since this is not their product. Possible manufacturers are TOPLEO and B2GO but none of them mentions a TX6-H model.
Originally posted by Frankk View Posthttps://4pda.ru/forum/index.php?show...#entry82248937
http://www.hotmcu.com/wiki/PhoenixCard
IMG_20201225_093503.img for us to try out.
Thanks in advance.
Best regards
Frank
Try phoenix card v3.10, another SD card and a different firmware
I also some times have problem to write image on SD, then I do a format to normal, eject the SD. format again with windows format and then burn the image. There is possibly a compatibility issue with Windows 10.
Originally posted by tonygts View Post
Hi Frank, Would you please share this TX6 imagex
Thanks in advance.
You post here, to ask for help, and when people asked to share the firmware image, you seem to be quite reluctant to share. Then, how possibly can you expect help.
hey good day all, just found this forum, let's communicate to collaborate to make this community better.
you guy can have mine latest June 2020 firmware, if you need older version July 2019 just feel free to buzz me
8822 model
https://drive.google.com/file/d/1kSX...ew?usp=sharing
6330
https://drive.google.com/file/d/1ZvK...ew?usp=sharing
Thanks allanhoong
I installed your 8822 firmware on my TX6-H and recognized directly the RTL8822CS WiFi/BT module.
Of course this is not an AliceUX but works fine.
I don't know if this can be Updated since I tried to, but had the usual message "Now it is the latest version"
Hi, u CAN NOT direct online update due to this is custom rom image. you still got to load though sd card or pc either way. (check other post online how to)
Lastly, i don't see any point to keep updating and reinstalling all the app if OS working fine unleast the scenario in future apps update can't support but require android firmware, which is very rare changes for couple years to go.
Cheers, have fun
There are currently 1668 users online. 0 members and 1668 guests.
