[ROM] RedPoisonATV S905X STABLE NEW VERSION 2
Originally posted by Robert S View PostThis is the tx3 pro firmware that works on the nanya ddr. https://mega.nz/#!N8dRVTqB!iTJfPvnne...vtDG9A6dwcpbXA It would be amazing if you can get your Rom to work with this box. I would post a link on the tread where others have had trouble with this box, here on freaktab and on 4pda. I will donate now to PayPal to support your team. Thank you in advance.
Hi minixfreak, I tried to get this firmware to work on tx3 pro with nanya ddr by changing the dtb file with customization tool then repacking. No luck, also tried with other custom roms and different combinations with files. Still no luck, I am no expert. Only follow tutorials that I find online. Did you get a chance to look at the firmware I posted in the quoted text? Do you think that this rom can work on my box?
Originally posted by hugn View PostHello @all
will this ROM works fine with Mini MXIII-II?
Can it be flashed from SD card & witch version from the download is correct for Mini MXIII-II
Thanks a lot
Originally posted by hugn View Post2GB version -> "RedPoisonATV_S905X.img" should be the right one?
And yes, would like to use factory remote, therefore how do i replace the remote config and where to find the right one?
thx
Thank you for your support.
I downloaded the tool and check every option, but?. don?t really know what to do, where to find the remote config and how to replace it with the correct one (and where to get the correct one). So this is not handlebar for ?standard? user. To avoid brick my box I will stay with LibreElec
THX
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
THX
version
Originally posted by minixfreak View Post
Not yet but the only thing u change for ram is ddr partition in level 1
There are currently 3746 users online. 0 members and 3746 guests.
