i will do the same.
[ROM] RedPoisonATV S912 STABLE NEW VERSION V2
Originally posted by bajdalijas View PostI do like this ROM very much but I'd like to convert it to a non-ATV Rom because I use many apps that don't work with ATV Rom ( my IPTV service provider app for example). I already tried to flash zip file with framework/framework.res, bin/permissions, priv-app/ tvsettings, launcher, phonesky, prebuiltgmscore, uisettings apps from stock Rom, but it says when I try to open Google Play Store ,that this version isn't compatible with atv rom. In a past I had successfully managed to convert other ATV Roms using this method. Any help would be appreciated. Thanks in advance
anyway
you can try to install by apk and use sideload launcher or use tv app repo to create a home link to the desired apps.
sorry for the beginner's answer because I think you're better than me with android, reading what you are be able to do lol.
it's basically the same device. a little difference with the chip on the right.
minixfreak any idea about why on same devices with same software the resolution settings capabilities could be differents?Last edited by papla83; 02-28-2019, 22:43.
On another new lpddr build will be soon and a new theme black and whiteLast edited by minixfreak; 03-01-2019, 02:26.
Hi Minix Freak, When can you fix on your Firmware the Remote issue on the Minix U9H to turn on the box and the USB on the box. It stopped working when I put yiur Firmware. SD Card is working. I know im asking a little bit to much but yiur Firmware is awesome I know that with a little twick you can Do it. A lot of people with the Minix U9H would be happy. Just needs a little twick come on Minix Freak Im counting on you!. V2 Red Pioison Firmware.
Originally posted by antonio6o6 View PostHi Minix Freak, When can you fix on your Firmware the Remote issue on the Minix U9H to turn on the box and the USB on the box. It stopped working when I put yiur Firmware. SD Card is working. I know im asking a little bit to much but yiur Firmware is awesome I know that with a little twick you can Do it. A lot of people with the Minix U9H would be happy. Just needs a little twick come on Minix Freak Im counting on you!. V2 Red Pioison Firmware.
I will working on that by today.
Hope we can fix it.
But I need you that you can Test it.
Regards
Neomode
There are currently 2000 users online. 4 members and 1996 guests.
