[ROM] RedPoisonATV S912 STABLE NEW VERSION V2
Originally posted by minixfreak View Post
Trust me v2 is a improvement ...
For sure TWRP is enough reason for me to flash another time. Flashing is a breeze, setting up al those apps is another thing :-/
Sorry, don't want to be annoying but I feel a little color-blinded by this Red/Blue...I'll go for Purple, especially as a Prince fan ;-)
Originally posted by Dmitri51 View Post
Would be nice if you could realise this! What do you need to make this work?
Originally posted by antonio6o6 View Post
I changed the remote. Cof I put the originals configuration remote. Cof from my minex H9U on firmware red poison V2 but it don't want to turn on. It turn off the box but dont want to turn on and I have to do it manually and the USB dont work on that firmware
Neomode
Originally posted by ZeroZorro View Post
And by improvement you mean V2 Red over V1 Blue?
Hello, my box is R BOX PRO 3G ddr3/16G with q9377 chip, but the ram is showed 2G in this ROM (I flashed RedPoisonATV_V2_S912.img). It was correct(3G info) in Atvxperince 2FF & previous rom. Is there any way to get 3G ram?
Originally posted by ado0813 View PostHello, my box is R BOX PRO 3G ddr3/16G with q9377 chip, but the ram is showed 2G in this ROM (I flashed RedPoisonATV_V2_S912.img). It was correct(3G info) in Atvxperince 2FF & previous rom. Is there any way to get 3G ram?
I put it on the list for fixes.
Neomode
minixfreak - just FYI. I have unpacked Blue and RedV2 versions to see the (binary) difference. I have replaced /system/lib/amplayer/* files from blu variant to redv2 (I have also used the correct chown and chmod...). I have also added libgifdecode_jni.so and some missing (probably camera related) xml files to /system/etc/permissions.
OpenMAX still does not work. There are also some *.apk files different - but they seem to be Red/Blue or Google related.
It does not meen that OpenMAX is not fixed. Probably I'll try to install Red V2 later. Personally I prefer blue theme.
PS I am not an expert in Android, but have good knowledge on Linux.
There are currently 4859 users online. 1 members and 4858 guests.
