Quick question: Would flashing these images from TWRP take care of resizing the system partition to 2.0 Gb when the device is currently on Marshmallow (with ~1.5 Gb system partition) ? Because that's really the problem that I'm trying to address.
[ROM] RedPoisonATV S912 STABLE NEW VERSION V2
Originally posted by yyzyyz View Post
That would be awesome, thanks a lot!!!
Root is built in by default ... shut it off in settings and restart
My apps astro go, although didnt detect root and successfully opened, howevsr due to ctsprofile and basicintegrity failed from safetynet check, the app still cannot run correctly.
I guess no choice, i have to live with it for now. I will temporarily use my other t95z box running poison rom 4.0.
Once again, thanks.
May i know if this is normal, after disabled root access in setting and once reboot it automatically on back.
Originally posted by neomode View PostHello Guys,
New Version is up, please check the first Post.
Neomode
I don't mind hopping from one colour to the other but I am just curious if it's just a mather of taste (GUI, layout, etc.) or is there more under the hood which could influence my choice to stick with a colour of Poison?
Originally posted by ZeroZorro View PostThanks, in the mean time I am getting a little confused: what's the main difference between blue, red and future color-detions (black as proposed earlier)?
There's a changelog. . I fixed some things
I will try to cross-check those changelogs to determine the differences between the versions and which one suits best to my current hardware. Tested both and they both doing a great job, especially for v1.0's
I just thought there might be a different angle of those two builds that could explain why they exist side-by-side in the first place.
There are currently 2686 users online. 0 members and 2686 guests.
