justXBMC "new firmware for k-r42"
not just yet. but soonEverything is possible if we work together!
Yes and no,
generally no Wifi because of different chip-set (and because of that no Bluetooth)...
yes if the rest fits, perhaps lan...
normally you have to use, because of the AP6210 (WiFi/Bluetooth), one of these rom
T-R42 custom firmware by wasser
NEW - Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA
normally wasser rom includes xbmc
PS:
But perhaps you have to use (try) this
T-R42 2.0 Board Firmware by lewy20041
And generally for xbmc have a look at
Beyond XBMC (Beta 3.3)RK3288 Devices
- Overview BOX (LINK !)
if have tried justxbmc yesterday and it worked nearly perfectly. I have no problems with WiFi. But when i have watched a series it will crash with a strange screen (stripes and bricks). I my manual it says that i have a "T-R42 ||".
What i want to do:
i want to have the box to start directly into xbmc. Is this possible with the fw of wasser ?
thx
RK3288 Devices
ok, I just installed the k-r42 XBMC-only firmware on my CS918...now it didnt turn on!?
It only shows the red light...but didnt turn to blue(like it would do then it starts)
what can I do now?
This are the Details of my Android TV Box CS918
Model rk31sdk
Android 4.2.2
Kernel Version
3.0.36+
arron@develop-server #201
Build-Number
rk31sdk-user 4.2.2 JQD39 user.arron.20140308.151002 test-key
Vendor software version
RK3188_R-Box_Android4.2.2-SDK_V1.0.0_120514
I hope you guys can help me out:/
please try to reflash if that dont work try difrent firmware as probably your box isnt first revision of k-r42 for witch this firmware is designed:"Everything is possible if we work together!
Originally posted by jobber2001 View Postwhich Firmware can I use?
I would like to use an XBMC Only firmware if possible!?
Originally posted by mitchell4you View PostHi,
To figure out what firmware/kernel works for your unit
We first need to know.. what version/revision you have.. this is done by opening the unit
And then looking at the pcb/motherboard
As reference for some models
Note.. to open-up the unit
There are screws under need the rubber-pads of your unit
GoodluckRK3288 Devices
There are currently 5599 users online. 3 members and 5596 guests.
