justXBMC "new firmware for k-r42"
Originally posted by pes1313 View PostYes it works,you may take this kernel and justxbmc 1.1.1 and this will work (sleep)
seems that fixed everthing.
oh ya before i forget do you get random shutdown on it ....
like many multi color lines then power off or
getting xbmc forcestop upon wake with airmouse
Originally posted by pes1313 View PostI'm also not working kernel 111113 for this rom and 2.0.4 too, i am using kernel from wasser 1.2 rom work perfectlyRK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostDo you have the kernel of this version for download because only version 1.2.1 of wasser rom is available...
pes1313 which kernel is it that working great 1.2 or 1.2.1
Originally posted by tonyg View Postwell i put 1.2.1 wasser kernel ...working ok far better then this original justxbmc
pes1313 which kernel is it that working great 1.2 or 1.2.1Last edited by pes1313; 16 November 2013, 20:27.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
Originally posted by lewy20041 View Postsorry i dont use screen mirroring so cant tell.Last edited by pes1313; 17 November 2013, 06:59.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
Originally posted by pes1313 View PostI think that the most likely rom 1.2.1 kernel 111113
ChangeLog say for 1.2 the date is 2013.10.13...RK3288 Devices
Originally posted by no_spam_for_me View PostNo, I don't think so, because the date of the 1.2.1 is 2013.11.05 (and the kernel date is 2013.11.04)...
there is same kernel
P.s
2013 .11.06 Wasser start topic: k-r42 firmware from Wasser (with 1.2 rom)Last edited by pes1313; 16 November 2013, 20:25.k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
Hey guys, I'm going crazy trying to get JustXBMC to work with the newer K-R42 2.1 device. I first had the no lan issue and it was suggested to flash newer wasser kernel. Lan worked but I lost audio. Just yesterday, Wasser created an even newer "revision" firmware (1.2.2) and that fixed both audio and lan. The problem is, I want the box to run XBMC natively.
So I figured I would use Wasser's newest revision's (1.2.2) kernel and flash it with JustXBMC. I get the same no audio issue, so that isn't going to work.
So 2 questions:
1. Lewy, are you planning to updage JustXBMC with Wasser's newest kernel for the newer 2.1 devices?
2. I see some have had success using Wasser's 1.2 kernal with JustXBMC. I'm having trouble locating that kernel to give that a try.
justXBMCv3.apk stater after 60min should be fixed passtrougt working with libmedia pached firmwares.
DownloadEverything is possible if we work together!
Its just the app for now not the firmware. If the feedback for the app will be ok the firmware will folow.Everything is possible if we work together!
There are currently 5958 users online. 1 members and 5957 guests.
