justXBMC "new firmware for k-r42"
    Originally posted by freestyle01 View Post
    Will you add support for the mouse?
    mouse works now
    k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
    rom 1.0.4 (kitkat) old revision Wasser
      mouse support is there in published ver already:"
      Everything is possible if we work together!
      ApkFreak
        Not excatly.
        In already version mouse doesn't have completely support. I compare mouse support in JustXBMC and XBMC 12.2 Frodo and in justXBMC version function "on hover" doesn't work. When I put mouse cursor on some options I didn't get any reaction from interface. If you know what I mean.
        I will show you the difference in mouse support between 12.2 version and justXBMC if You want.
          than show me as i dont know what you mean:"
          ApkFreak
            I will make some video for you which show difference in mouse support between justXBMC.apk and XBMC 12.2 Frodo. Hmm.. maybe in justXBMC software mouse works correctly? I use HFW 2.04 with just justXBMC.apk
              Question on cifs mounting
              i have insterted this inside the 98cifsauto file but nothing seems to happen on rebooting... no folders created and neither is the NAS linked to the player...... on other firmware i used the same line as below and that worked fine (install-recovery.sh) cannot use NFS (Nas has 2 seperate disks and works with CIFS)
              also played with the permissions of the file what didn't seem to help, what am i doing wrong ?
              the rest seems pretty stable, netflix works like a charm on this firmware and its clean looking. although Ethernet wired is still a no go on the unit.
              Code:
              #create folders
              mkdir /mnt/sdcard/nas
              mkdir /mnt/sdcard/nas/Films
              mkdir /mnt/sdcard/nas/Series
              busybox sleep 20
              #Cifs Auto Mount
              busybox mount -t cifs //192.168.178.200/Disk_2 /mnt/sdcard/nas/Films -o user=popcorn,pass=hour
              busybox mount -t cifs //192.168.178.200/Media /mnt/sdcard/nas/Series -o user=popcorn,pass=hour
              busybox touch /data/.notfirstboot2
              Home Cinema Setup Livingroom:
              50" Panasonic Plasma - CS-X806 (s802 1gb/8gb) with Mele F10 on OpenElec 5.0.3 with Kodi - Pioneer Receiver - JBL Surround System - 4TB NAS
              Bedroom Media Setup:
              32" Philips LCD -
              KR-42 wasser rom
                Hi Lewy, what do you think about this ?
                  if you can do it feel free to make it real;p
                  as of now i didnt found a good way to connect
                  externall bluetooth dongle to be used on rk3188 devices.
                  ApkFreak
                    I will try
                      @Lewy20041
                      Could You give me a link to Your justXBMC.apk ?
                        Originally posted by Irodal View Post
                        @Lewy20041
                        Enter to lewy's website -> find justXBMC.apk -> click download
                          Lewy, that the bluetooth dongle works on k-r42,bt dongle see my device(bt adresses), but it is impossible to bridge the after entering the command "hcitool cc", on the phone is a request for code ,I tried "0000" and "1234" but the main connections are not
                          Maybe I need another adapter, or is it useless?
                            Does work Navi-X on justXBMC ?
                              XBMC Bluetooth Sound Support
                              Hi Lewy20041,
                              Love your justXBMC.apk. Is it possible if you can make it work with Bluetooth audio as well. Video and Audio playback stutter bad when I turned on and used my Bluetooth headset?
                              Your justXBMC.apk right now does both Analog(No A/V Receiver) and DTS passthrough perfectly for me. Adding Bluetooth Audio playback would be a big bonus.
                              BTW, My box is T-R42 with Bluetooth.
                                Bluetooth scan
                                Hello,
                                I have a AC8350 board v2.1 with rom "justxbmc" 1.1.1 from Lewy and tried a Bluetooth dongle to see if it is recognized and can scan for other Bluetooth devices. On settings you can“t switch Bluetooth to on, tried it remote with Putty and that is the result
                                Using username "root".
                                SSHDroid
                                Use 'root' as username
                                Default password is 'admin'
                                /data/data/berserker.android.apps.sshdroid/home # su -i
                                root@android:/data/data/berserker.android.apps.sshdroid/home # cd /
                                root@android:/ # hciconfig
                                hci0: Type: BR/EDR Bus: USB
                                BD Address: 00:15:83:15:A3:10 ACL MTU: 339:8 SCO MTU: 128:2
                                DOWN
                                RX bytes:438 acl:0 sco:0 events:15 errors:0
                                TX bytes:65 acl:0 sco:0 commands:15 errors:0
                                root@android:/ # hciconfig hci0 up
                                root@android:/ # hciconfig -a
                                UP RUNNING
                                RX bytes:870 acl:0 sco:0 events:29 errors:0
                                TX bytes:127 acl:0 sco:0 commands:29 errors:0
                                Features: 0xff 0x3e 0x85 0x30 0x18 0x18 0x00 0x00
                                Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
                                Link policy: RSWITCH HOLD SNIFF
                                Link mode: SLAVE ACCEPT
                                Can't read local name on hci0: Connection timed out (110)
                                1|root@android:/ # hcitool scan
                                Scanning ...
                                00:0D:F0:45C:C5 n/a
                                Scanning ...
                                00:01:E3:B3:1D:A1 n/a
                                00:0D:F0:45C:C5 n/a
                                root@android:/ #
                                two devices are recognized, the dongle works I suppose it is supported in the kernel. Right ?
