justXBMC "new firmware for k-r42"
GOOD CHOICE
Originally posted by bluesmanuk View PostBrilliant
I shall carry out some testing when my machine arrives tomorrow.Last edited by PHYSC; 17 October 2013, 21:52.What is the world if you don't explore?
tvheadend Q
Awesome firmware - thanks a tonne
Pushing my luck I know, but any chance you could consider bundling in tvheadend support, and USB DVB-T stick support?
I have been toying around with this based on thread on xda (http://forum.xda-developers.com/show...2171412&page=3) - rockchip mk808 based, but working on assumption the similarities will apply. Would obviously depend on the stick, but seems base kernel modules are the same (original source http://www.holik.at/index.php?m=06&y...y130627-175237). Reckon it would be a sweet setup to have TV/PVR all in same device.
I haven't yet gotten my stick recognized, but that's probably user error
Originally posted by PHYSC View PostThanks Flumpster i realy appreciate the help you give me, i am sorry for the late response i wasn't feeling great and slept through some of today,but here's the vold.fstab mate.
##$_FOR_ROCKCHIP_RBOX_$
## Vold 2.0 Generic fstab
## - San Mehat ([email protected])
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
## label - Label for the volume
## mount_point - Where the volume will be mounted
## part - Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> - List of sysfs paths to source devices
## Example of a standard sdcard mount for the emulator / Dream
# Mounts the first usable partition of the specified device
#dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
#dev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9
# $_rbox_$_modify_$_huangyonglin: added 2012-02-23, for adding the mass storage supporting.
dev_mount sdcard /mnt/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
dev_mount udisk0 /mnt/usb_storage/USB_DISK0 1 /devices/platform/usb
dev_mount udisk1 /mnt/usb_storage/USB_DISK1 1 /devices/platform/usb
dev_mount udisk2 /mnt/usb_storage/USB_DISK2 1 /devices/platform/usb
dev_mount udisk3 /mnt/usb_storage/USB_DISK3 1 /devices/platform/usb
dev_mount udisk4 /mnt/usb_storage/USB_DISK4 1 /devices/platform/usb
dev_mount udisk5 /mnt/usb_storage/USB_DISK5 1 /devices/platform/usb
# $_rbox_$_modify_$ end
## Example of a dual card setup
# dev_mount left_sdcard /sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
# dev_mount right_sdcard /sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1
## Example of specifying a specific partition for mounts
# dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
That is the same file as I edited before for you. Just use the one I posted in the other thread and it should work.To Infinity and Beyond.... XBMC
Originally posted by PHYSC View PostI have used it mate but upon reboot it locks on ouya partial sign?
I have not tried this firmware yet but I can tell you that the vold.fstab you posted above is identical to the one you posted in the other thread before so the same file that I gave you before should work unless you have pasted me the wrong file.To Infinity and Beyond.... XBMC
if no you need to do that or it will not work:"Everything is possible if we work together!
Originally posted by lewy20041 View Postdid you copy all the files from internall sdcard to your microsd card before swiching vold.fstab?
P.s Can "play market" there are programs that can fix "sleep" without changing the firmware?k-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
i think sleep dont work as it should in HFW due to kernel.
i need to catch wasser and ask him if he can solve itEverything is possible if we work together!
Originally posted by lewy20041 View Posti think sleep dont work as it should in HFW due to kernel.
i need to catch wasser and ask him if he can solve itk-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
I have a one stage yes but upon a reboot it hangs at the ouya loading page
I suppose a good question would be in which mode xbmc or ouya mode do i copy the volod.fstab over or do i copy all files in xbmc mode to sd and then when switched to ouya do i then copy all the files over to the sd again then switch the vold?
Basically if i use the current vold file it then if set to mass storage option it has greyed out sd card and greyed out external sd card also stating unmounted in settings as well?
Also to ad is that when switched to mtp again it gets GT-I9300 installed but the disk shows as totaly empty nothing in it and i cannot seem to copy vold fstab file to it as refuses to use as storage?
The best thing here would be for someone else to get the firmware running and ammend the fstab then upload the fstab file to a download site like mediafire and such,this way we have a working file to use and then everything else is user error which can be assessed
Update:When i manage a fresh install of the firmware and i look in storage sd card is greyed out any way?
I am now begining to wonder if it relates to the fact the sd disk was set to logical partition in minitool? Any how i have now set it to primary and i am doing a reflash so fingers crossed it get's detected as a sd card now in ouya firmware?
Weird guys if i format to primary and reinstall firmware i get a weird kernel panic message appear as follows :
ERROR IN ACTION NUMBER 1 OF EVENT:HTTP FOR OBJECT SOCIAL_OBJ:
DATA STRUCTURE WITH INDEX DOES NOT EXIST.
AT GML_SCRIPT_JSON_GET
SATCK FRAME IS
GML_SCRIPT_JSON_GET(LINE0)
GML_OBJECT_SOCIAL_OBJ_OTHER_62
The above was showing up in lower case when booting and it just doesn't go away now?
I must say that i am perplexed by it,i have noticed also when reflashing or simply flashing the fw over to the device,upon booting it takes maybe 4 reboots as just xbmc loads and causes a garbled graphics when using the menu the system power off for a reboot then? After much agrevation i manage to force the launcher app to then switch firmwares,so my question is is there a bug in the system with relation to the sd card? As a result i must have reflashed 20 times now trying every way under the sun for the sd to be read,what would be cool would be a sd car vold.fstab firmware with sd card as internal storage preset,i am guessing the workload may be great i am unsure?
Maybe an idea would be add in advanced settings a extra switch to switch to external sd card as main storage then when it reboots go back to advanced and switch to ouya firmware and have the switch incorporate the files then being written over to the external sd so it uses it as the boot partition? It's a massive ask i know but maybe if it isn't going to happen which i wouldn't blame Lewy20041 if he doesn't want to do that as the work would be excessive for a small option setting,and i am guessing Lewy20041 has already set his sd card as main storage option,i just can't believed i have hit a hurdle like this and been unable to resolve it yet,as normaly i can eventualy hit the mark with a hell of a lot of reading and the perserverance but my frustration is getting the better of me now.
If anyone could teach me in laymans enough terms how to develop and modify an android devices firmware or how to manipulate android os via pc to achieve a basic programming knowledge that would be sensational, as i feel i could contribute to projects as i am the kind of guy that once he knows how to do something,then it's only a matter of time with me persevering around the clock that i eventualy always get what i aim for.This would make subject matter like editing a vold.fstab a breeze at most.And i would like to make some helping apps maybe the likes of a app that switches internal storage automaticaly for a k-r42 so you need never edit a vold.fstab again on it.I'm probably dreaming as a beginner learning android that i could accomplish that,but i'd more than love to learn android basic programming on afrom a laymans terms perspective,just so i can understand it would be good enough,maybe at least if i understood it i could edit files manualy.I'm not what can be called a complete noob when it comes to flashing devices and have done many mods repairs on idevices and varied phones eg. my Haipi i9377 generic china mobile and rewrote the imei back to it after the flash,done other things like go pro cameras and so forth,idevices and blackberry's the idevices i feel i have now mastered,i am what you'd call a computer repair technician in theory no formal certification but i train voluntarily at a family friends shop,well i say train i have done 1 day a week for 3 years now so i can help them out and learn a bit,i love it as it keeps you informed and up to standard on modern tech they also stock tablets now so we do a bit on those from time to time, i often shim laptops and strip rebuild them for charging socket repairs i don't solder them my self but i replace the oines on a lead and sometimes stripping them to bare bones i've even reflowed and shimmed a inspiron 1546 with my atten 858d+ heatgun,in the shop i diagnose and repair machines that come in, this can be software related or hardware related,also from time to time we get different little niche things to do like the odd mac all in 1 or a random request for a software program to be toy'd with to make it run or even a tomtom gps oer a garmin possibly sometimes we get a generic branded tablet from china to mess around with restoring or adding apps and so forth you get the picture,so i have a vast knowledge of some fields and although it took a lot of guidance to get it in my head enough to become second nature,i still feel i can work alone or as a team repairing when under pressure if inundated,but i also have a strong willingness to learn android development or manipulation of android operated devices to do as i would like it to do and as would others would like it to do.Last edited by PHYSC; 18 October 2013, 22:20.What is the world if you don't explore?
ouya launcher won't start
keep getting this message:ERROR IN ACTION NUMBER 1 OF EVENT:HTTP FOR OBJECT SOCIAL_OBJ:
SATCK FRAME IS
GML_OBJECT_SOCIAL_OBJ_OTHER_62 tried uninstalling and reinstall and still the same message and I have not messed with the vold fstab file or any other files
Me to
Originally posted by bloatman View Postkeep getting this message:ERROR IN ACTION NUMBER 1 OF EVENT:HTTP FOR OBJECT SOCIAL_OBJ:
SATCK FRAME IS
Think i have it i held home button got in to launcher i removed the 360 wifi reciever and then chose launcher for ouya in apps with the ethernet out it doesn't panic but if i plug it back in it does? This appears to me like a server issue of some kind? Without ethernet it does not panic but with ethernet it does?Last edited by PHYSC; 18 October 2013, 22:57.What is the world if you don't explore?
its probably due internet conection.
check if your internet conection is working as launcher relay on it:"Everything is possible if we work together!
There are currently 5539 users online. 1 members and 5538 guests.
