[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
    Force erase all when flashing firmware through sd or usb burning tool
      Great job! But I can not wake up device by original remote, and sleep not working with air mouse. My device is krizer u5x.
        I?m using force erase all but it doesn?t matter.
        SD card goes ok in V3.
          So far so good!
          Flashed problem free with SD-card method on my T95Zplus 2/16
          Only minor problems like before:
          * OK/Select button on remote does not work in mouse mode.
          * No LatinIME included so can't disable on screen keyboard afaik at the moment
          Will do more tests coming days and report back.
          Thanks to all developers on this one!!
            Originally posted by ZeroZorro View Post
            So far so good!
            Hello,
            Thanks for your Review.
            For the keyboard you want please look in playstore there is an keyboard app with this name to enable what you want.
            The other problem with your IR Remote I think it is only a mapping problem with remote.cfg.
            Neomode
              Thanks....
              Null Keyboard seems to do the job, but has to be sideloaded...
              I will dive into remote.cfg soon
                Any idea for flashing nexbox a1 throught sd card ?
                  When i goin to see update on firmware v4? .on my minix u9h. Control power on issues. Usb port not working.
                    Hi there,i have alfawise h96pro+ v3 ddr4 what rom should i install? I mean s912 lpddr.img or s912.img?
                      Originally posted by minixfreak View Post
                      i will look into this ... what exactly is not working ?
                      We'll i am waiting seen v1 v2 v3 v4 ? Firmware. Remote won't term box on. Usb port not working.on minix u9h. It seems like not going to been help
                        Then use stock firmware or make your own ... u think it's easy to fix something u don't actually have ... I been working to fix the issues I have with my firmware first then do device specific. .. minix is different how they built their firmware ... it's not as easy as you think
                          Thank you for your time and sorry for your convenience.
                            well i whet back to stock firmware. i have waiting seen firmware v1 v2 v3 v4 .
                              After few days of use I must say this is best Poison ROM so far!
                              Fast and clean, all Googleplay (or sideloaded) apps are working like they should.
                              No hiccups yet, BT and Ethernet just fine. Wireless not tested yet.
                              Some small things, hardly bugs, I noticed:
                              - Boot animation: sound is a little off, don't remember if it's behind or visa versa.
                              Also a little green thing just after logo and before animation which doesn't belong there I guess. Volume is just fine ;-)
                              - Seems Aptoide TV does not recognize this device ID very well, some apps are missing or showing wrong version. For instance it wants to update Netflix but that doesn't work. I use Apkmirror instead without any problems.
                              - Once or twice it stopped responding to my remote, can't reproduce this one yet. But login with TeamViewer (or even Cetusplay) gave me the opportunity to press Home button and after that remote just works. One time I switched remote off-on and that reinitialized the connection.
                              Still have to test game controller in conjunction with Google Games and Kodi Games ... Curious about that one
                              Thanks again for an amazing ROM guys!!!
                                I managed to install this Rom on m8s plus L but wifi doesn't work. How can I add the wifi drivers for sci s9082c?
                                if it is not possible, is there an usb wifi adapter that can work for this Rom? I would love to get this working.
