[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
    Originally posted by minixfreak View Post
    reburn it with usb burning tool v2.1.7 with erase all option on ....
    I have solved the Google store problem and initial setup.
    Taking your advise, I reflashed 2X again force erase all option.
    1st time failed half way and this time, I disconnected the usb cable to start over.
    In previous round of flashing that I didnt disconnect and start over.
    That maybe a reason I was having initial setup problem for google store.
    Once again, thanks.
      How can i install google chrome on this rom? I cant find the right apk.
        Anyone have any luck with the T95z max? I've tried multiple times to install...all goes well on usb burn tool but it won't boot up when connected to TV. I have successfully put back orig firmware and all works well...and help would be appreciated. Great work team!
          Use the preinstall TVAppRepo to install chrome.
            wanna try poisonatv but mega link is dead
            is there another way to get the rom
              Are sure you use the right files?
              If not mistaken S912 is for DDR ram and another img is for lpddr ram.
              I dunno t95z max, but worthwhile to know your own box in more details.
                Thanks you
                  Hey muncheno, thanks for getting back to me. Yes, I'm using the lpddr version. I have the T95z max 2/16 with the red board. I've installed the v1016-EB-AGCF-LPDDR3-2G to get it back to its original state with no issues. When I burn using the USB Burn Tool 2.1.7 I have selected force erase all and erase all...install goes through fine no errors, but when i connect to my tv and power it up I get nothing. I've installed on my other amlogic 905w boxes with no issues...this LPDDR box is weird.
                    Originally posted by caliban_freak View Post
                    Whitch img is the right one for the H 96 pro plus? I try the PoisonATV_V4.5_S912 but when i set the sd card back in the box, the upgrading screen comes only a few seconds,than it went to black?? When i try the PoisonATV_V4.5_S912_LPDDR and insert the sd card to the box nothing happen, it won?t upgrade. Ps i use Burn Card Maker
                    Use usb to usb not sd
                      Okay just bought an male usb to usb. But something is wrong. Usb Burning Tool stop at 2% with error 0x10105002 Romcode Initialize DDR Read initialize status Usb control setup Error. What can i do?
                      What i try is using a difernt usb cable, another usb port and a lower version of Usb Burning Tool.
                        Can confirm your method of flashing eith usb burning tool?
                        1- Disconnect all the cable and usb and memory card from your box (to avoid power issues)
                        2- start usb buring tool from PC with image loaded (assuming your usb driver already installed properly)
                        3- Once iimage loaded successfully, tick on the option for force erase all and tick erase bootloader normally only needed when flashing different android version.
                        4- connect male2male usb cable to pc first
                        5. On your box, press and holding reset button then connect to male2male cable.
                        (to be safe dun let go your reset button yet until it goes beyond 2%, normally I wait until start to formatting)
                        6. On your pc when you see usb connected, then you press start.
                        Edited: In some unsual occasions you may needed to flashing 2-3x in order for it to reach 100%.
                          Download link not available. Any alternate link please?
                            This Rom is 32bit or 64bit?
                            I used AmlogicTool to convert img file to enableflash zip file, then used TWRP flash it, but my box cant boot, it is loop at boot logo
                            (I'm using rom SCV4A-ATV 64bit of Superceleron)
                              Hi, please repair the download link. Not working. Thanks
                                alright guys neomode will update the p0ost later , but here are the links for v4.5 .... i never did a changelog but it should be stable with no bugs
                                https://mega.nz/#F!A8BihSCb!EA2vnBM6sqVX8BYll-W_PA
                                U have to look a page or two back! Dont just wait someone to do your job.
