[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
NUEVO V4.6 AQU? https://mega.nz/#F!ItZSWQiJ!kRP7BQpKjAOXSIo0oXN11w greetings I want to congratulate in uppercase this new update is loaded with USB cable report netflix 4k HD functional in iptv works very fast and loose I do not like how it looks youtuve vance I would like to see small menu and with maximum definition in the mode androit tv the images they are very large definition is lost in led panatallas superior to 50 inches the room is very very good one of the best data takes and handles wifi use S912 2 ram equipment sunchip
Originally posted by minixfreak View PostNEW V4.6 BUILDS WITH CHANGELOG AND INSTRUCTIONS THIS IS FINAL .... LINKS ARE HERE https://mega.nz/#F!ItZSWQiJ!kRP7BQpKjAOXSIo0oXN11w
Hi Guys
Was wondering if the driver below is part of your kernel? If not how do I apply it?
It is for a ASIX AX88772C USB2.0 to Fast Ethernet Adapter
ASIX is a Leading IC Design Company for Industrial/Embedded Networking and Connectivity Solutions. email to [email protected] or call 886-3-5799500 for further products information.
neomode made a patch with drivers for a orico usb to ethernet adapter, but it is not working. maybe I applied it incorrectly?
Please help.
Originally posted by antonio6o6 View PostMinixfreak I finally got my remote control working turning on and off on my Minix u9h. A3 Remote control.using firmware 4.6. I change a couple of numbers on remote control configuration file. End working now finaly
Verstuurd vanaf mijn WAS-LX1A met Tapatalk
On the remote configuration file I change
On line 67 . 115
on line 75 . 116
on line 120. 116
that's all what I did and my Minix U9h. It's working great the new remote I turn off my box and turn on my box I wait a couple of hours to make sure did turn on all depends on which version a firmware where you are using I use firmware 4.5 do the job great the new firmware 4.7 Do turn on the Box in off but I got Issue video problems if you use 4.5 and modify remote conf.the A3 remote is going to work like a charmLast edited by antonio6o6; 04-20-2019, 14:06.
Originally posted by antonio6o6 View PostOn the remote configuration file I change line 67
On line 67 115
on line 75 116
on line 120 116
Originally posted by papla83 View PostHi.
I can't found any link to test 4.7, is it normal ?MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 20GB now
{ROM} PoisonATV V4.8 S912
[QUOTE = antonio6o6; n769981]
https://mega.nz/#F!NhxCkQLb! YU0W6OZqxi20V8tqZpsdeQ
Meecol m8s Pro s912 uygun olan 3GB Ram modeli
Hangisi benim i?
İn doğru antonio6o6Last edited by ozkan16; 04-25-2019, 23:00.
H96 Pro Plus first impressions , long time atxXperience users, observations:- Had to flash a second time and select full erase to make the google play store work (USB FLASHING)
- I like the boot, it is quiet.
- Rugged clean look
- I like that tv app repo is installed, bottom bar is handy.
- amazon tv appears to work
- do not like the cursor, wish there was a larger easier to see cursor
- tvapprepo would not install chrome just two leanback shortcuts, something wrong with it. was able to go to the google play store, get puffin browser and install aptoid instead.
- tvapprepo was able to create the leanback shortcuts for prime tv.
- check that DTS is enabled in the buiild.prop file
- see if all my apps work normal with crashing
There are currently 2244 users online. 11 members and 2233 guests.
