[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
Okay i finally did it. But i?m on 4.3 and remote won?t work. How to upgrade to 4.5? It?s an img file which can?t be loaded with twrp.
--edit-- okay, try to install 4.5 with twrp, but it doesn?t start File larger then target device error
--guys please help me to get my H96 Pro plus running with Poison 4.5--
-- went back to Version 4.3 but my remote control isn?t working. Someone got an Answer how i get my Remote back to live?--Last edited by caliban_freak; 13 April 2019, 21:07.
Originally posted by caliban_freak View PostOkay i finally did it. But i?m on 4.3 and remote won?t work. How to upgrade to 4.5? It?s an img file which can?t be loaded with twrp.
Why you insist using sd card method or twrp?
When i try with twrp i get an error file is bigger than target file. So anyone have a flashable .zip from the 4.5? Or can help me with my remote control problem?Last edited by caliban_freak; 14 April 2019, 11:49.
NEW V4.6 BUILDS WITH CHANGELOG AND INSTRUCTIONS THIS IS FINAL .... LINKS ARE HERE https://mega.nz/#F!ItZSWQiJ!kRP7BQpKjAOXSIo0oXN11w
Originally posted by caliban_freak View PostCan i flash it with twrp?
poinsontv V4.6 works perfect was eliminated the problem that does not recognize network is fast only that I can not place netflix hd 4k compatible please place link of the compatible apk and I would like to know how it was with iptv youtuve vance the icons look very big it would be more nice that it looks like a fura pc the rapides of the computer impreciona great work I have a S912 sunchip x12
Minixfreak on firemware 4.5 sleep mode work good on my minix u9h. but on fireware 4.6 not working well like on firmware 4.5. Can't you help me out on firmware 4.6 so I can put my minix u9h. Sleep mode to work pls. can t you tell me whit file to move on 4.5 to 4.6 so sleep mode can work. using file exploterLast edited by antonio6o6; 17 April 2019, 22:18.
Originally posted by antonio6o6 View PostMinixfreak on firemware 4.5 sleep mode work good on my minix u9h. but on fireware 4.6 not working well like on firmware 4.5. Can't you help me out on firmware 4.6 so I can put my minix u9h. Sleep mode to work pls. can t you tell me whit file to move on 4.5 to 4.6 so sleep mode can work. using file exploter
There are currently 2625 users online. 2 members and 2623 guests.
