[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
Originally posted by Newfie Chick View PostTested Rom, could not wait lol. No luck getting to login to my account Google account. Internet was hardwired, disconnected hardwired connection. Switched to Wi-Fi same result. (No internet connection, check your Wi-Fi or get a notification when your connection comes back).
Confirmed internet connection the whole time. Rom is running on my Alfawise 96 Pro +
Thanks,
NC
Originally posted by minixfreak View Post
glad its working ..... I do have internet connection everything else on the ROM is working correctly but each time I click on Google play I get the same message (No internet connection, check your Wi-Fi or get a notification when your connection comes back).
thanks for the reply, but still having no luck logging in to Google play. I do have internet connection everything else on the ROM is working correctly but each time I click on Google play I get the same message (No internet connection, check your Wi-Fi or get a notification when your connection comes back).
reboot your router and modem then retry ... i have tested it t95z t95u km8 pro bb2 and it all worked
Side note V4.0 no issues. I will hold off and reverting back, i will just side load a few apps that i use from Google play. BTW i like the Youtube app you have in the ROM
Thanks,
NC
Sorry minixfreak, no go. Hardwired internet connection & Wireless internet connection no difference. Rebooted HSI (high Speed Internet) wireless modem no luck. Maybe its just the hardware as i am running a Alfawise 96 Pro + Green board.
Thanks,
NC
Burn with the newest burning tool .... then erase all not normal erase will fix issues ....
I only manage to get google play running on V4.2 by restore google play and framework services, etc via Titanium backup and reboot.
I have T95Z and H96pro+, both same issue...
Originally posted by muncheno View Post
Not sure this help.
There are currently 1850 users online. 2 members and 1848 guests.
