[ROM] POISONATV S912 NEW V4 [20190317] *UPDATE*
    Is it possible to (dirty) flash 4.2 on top of 4.0 to preserve most of apps and settings?
      How to change PoisonATV rom wallpaper version 4.2???
        Originally posted by minixfreak View Post
        Its a minix specific issue and I told you before ... I will look at that issue soon please stop spamming or u will be banned
        Ok got it. I Got it I still love you MinixFreak!!
          With 4.2, I have problem with startup.
          Where it fail to check for updates and given option to configure network.
          Try both options given with 2 reflashing.
          ​​​​​If i choose continue everything seems okay until I goto Google Play store.
          I keyin the id and and password, it atate successfully.
          However failed on google services, an error message on the screen.
          "Error retrieving information from server: DF-DFERH-01"
          Is I the only one with this problem?
            I have Tanix tx9 pro and I never managed to have working clock with with pathes provided here- I have to flash stock boot and bootloader on order to have working clock.
              I have testes 4.2 Finally v4 worked for me using sdCard flash. For now everything is ok, the only one thing that i am not fan is to have an image as background in the appdrawer.
              Thankyou
                We tested this on multiple devices and the issue was resolved with 4.2 make sure ur flashing 4.2 link is a few post back
                  Thanks. Maybe i downloaded a defect img. No problem on V4.
                  Will try download V4.2 again on tonight.
                    The superceleron atv rom (https://forum.freaktab.com/forum/tv-...oid-tv-version) had widewine L1 preserved but this rom only has L3. Is it possible to improve the rom to L1?
                    Also I am trying to run an app that need a google certified device (com.dstvmobile.android). It says my device is uncertified. Is it possible to make this ROM google certified? I have already tried using magisk with some modules said to be able to to this, but it failed.
                      I gave up on V4.2, will go back V03.
                      Thanks.
                      Still fail to get google play running and alot of app fail to run due to google service.
                      Will test again on next version.
                      Edited: managed to get running by using titanium restore google stuff from mh other box running V03. After restore and reboot, everything seem good now.
                        Hello,
                        There is no way to make this Device Google Certified.
                        If you want to have this it will be a long way and Working with Google to get it certified.
                        Only way you can do buying a box that is certified by Google.
                        Like Nvidia Shield etc.
                        Neomode
                          Hi (Mecool M8S PRO) possible to install with usb tool? POISONATV Thanks.
                            Originally posted by neomode View Post
                            Hello,
                            Neomode
                            That is not completely correct.
                            I have used this procedure (https://forum.xda-developers.com/app...2#post77044632) to make any s905x / s905w google certified and I could use https://apkpure.com/dstv-now/com.dstvmobile.android without problems
                              mods, please delete this post
                                neomode
                                POISON ROM I've installed on the TV box is locked HDMI doesn't display only the light is on fire solution please
